OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by clarkss12 View PostMighty Text is an Android app that I used for text messaging. I did some search on the web and here is something I found. Website >> http://www.themagpi.com/issue/issue-...c-and-raspbmc/
Here is what it said. >>
"The advanced options under XBMC Remote Settings include Show incoming SMS and Show incoming calls that enable a small pop-up notification to appear on the TV when you receive a text message or phone call. This does of course require you to keep your smartphone constantly connected via WiFi to XBMC which can drain your smartphones battery somewhat, hence keep your phone on charge."
I tried to find those settings in my OpenELEC, but could not find them.
Do you have yatse remote on your phone? A plugin from that App sends the sms over local network
Originally posted by ccadi View PostDo you have yatse remote on your phone? A plugin from that App sends the sms over local network
I have not tested it by having someone else text me with their phone.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by MikeD View PostI think if you have yatse on your phone your kodi box displays all YOUR incoming messages. Doesn't matter if the one who send you the message have it installed.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Sound from AV port
I am trying to get sound from the av port for my amp, here is my aplay output:
# OpenELEC - The living room PC for everyone #
# ...... visit http://www.openelec.tv ...... #
OpenELEC (unofficial) Version: 5.0.3
OpenELEC:~ # aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: AMLM8AUDIO [AML-M8AUDIO], device 0: AML PCM AML-M8-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: AMLM8AUDIO [AML-M8AUDIO], device 1: SPDIF PCM dit-hifi-1 []
Subdevices: 0/1
OpenELEC:~ #
and here is my asound.conf:
pcm.!default {
type hw
card 0
device 1 format S16_LE
ctl.!default {
type hw
card 0
Can this be edited to allow analogue sound to the av port as well as the hdmi.
I noticed a weird behaviour with resolutions.
Sometimes when i switch from hw decoding to sw one (also using the switch for using sw decoding for <720p files) the box sets itself on plain HD res (1280) instead of the original/saved one.
U can of course get back to settings and set it back, but *sometimes* the resolution option is not enabled.
Black Screen after logo????
Am I the only one that got black screen after the Tronsmart logo?
Flashing OpenELEC-Amlogic.S82.arm-5.0.3.zip and also 5.0.0 with the same results.
What to do on my Tronsmart Vega (Elite) S89 Amlogic S802?
Thanks for your help.
A
Update: The problem was that I used the wrong recovery file and the recovery file in OpenELEC-Amlogic.S82.arm-5.0.3.zip diden't work and made a black screen, so I had to use the one from OpenELEC-Amlogic.S82.arm-5.0.0Last edited by andready; 24 February 2015, 09:41.
Originally posted by andready View PostAm I the only one that got black screen after the Tronsmart logo?
A
Did you remember to wipe the Data + Cache? Kinda sounds like your stuck in a bootloop.
Also... Not trying to come-off as some smartarse here. But, were you sure about the File you downloaded?
That said.... I've tried a few of these Firmwares out on my 1G MXIII before, and really only One of those ever got quite close to a working state. I did say close... But, never quite.
A
BTW I have the round Beelink M8 box.
Is anyone using tvheadend server on their OE? I have OpenELEC version 5.0.3 installed on my Tronsmart Vega S89H and running tvheadend backend version HTS Tvheadend 3.9.2182 . My problem is that after a fresh reboot the time shifting works great, but when I change to a different stream or stop the existing stream, the time shifting no longer works, only a reboot will get it working again. Apparently it is a bug in this version of tvheadend. If someone that is using a different version of OpenELEC, can they check to see what version of tvheadend server it is using?
Everything is running great so far, and did not really want to roll back to a different version of OE if they are still using the same tvheadend server version.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2054 users online. 0 members and 2054 guests.
