OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by vermillion View PostProblems for me on 5.0.5 s82 build as mac address changes on each reboot.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostCan you test if you can write to a micro SD card using 5.0.5.
thanks
Installed via recovery, said successful but booted to black screen and a bit of a toil to get back to recovery
Originally posted by ccadi View PostTheres a replacement 505 on the site, I had similar problems to you. Trying replacement now
Installed via recovery, said successful but booted to black screen and a bit of a toil to get back to recoveryMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I have a MXIII branded to HausBell dont know if this means anything, Its a 2GB ram version.
I have downloaded a bunch of the OPENELEC images with the name MX3 in the file name. NONE will work. I get boot logo for about 4 secs and then black screen. the box just does nothing. I can then recovery and reflash to a working stock or another rom.
I even tested : OpenELEC-Amlogic.S82.arm <--- bad move after flashing this image the system folder seemed to have moved. anything I did after that would = ERROR 7 and abort the install.
I then used USB BURNER TOOL to reflash the box to a stock M82_108k4.img , That was fine. right after it flashed it rebooted.
So my list
OpenELEC-Amlogic.MX3.arm-4.97.2 to OpenELEC-Amlogic.MX3.arm-5.0.3
I have tested and all result in a blackscreen after the boot logo
anyone know whats up
thanks
Also I get frameskips at 24p.
I'm using the last version compiled today. Guess i'll go back to 5.0.0. for the time being.
Originally posted by RedNas74 View PostStill can't write to sd with 5.0.5. The last version that worked was 5.0.0.
I'm using the last version compiled today. Guess i'll go back to 5.0.0. for the time being.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
already so after messing around and looking threw the folders on the .ru site i came to find a file called : http://amlinux.ru/image/4.97.1/OpenE...utoinstall.zip = I downloaded that added it to my SD and flashed. BAM the MXIII booted with the openelec boot logo.
After that i then flashed : http://amlinux.ru/image/5.0.3/OpenEL...0.3-update.zip
the box works great.
some reports from my finding so far
under system info
Summary screen
Free memory is reporting 665MB free how is this if i have a 2GB unit ?
Hardware screen
Serial reports as : 1900000000000000
CPU temp reports as : 123F to 124F
Total memory : 817MB - again this is a 2GB unit why only half is shown
Free memory : 664MB
OpenELEC settings
Bluetooth : No BlueTooth Adapter Found.
Wireless and Wired work no problem
unit shows 4 cores running
I know the serial number dont matter , The cpu temp is just BS as i feel the unit and its not baking.
The one thing that i have a ? about is the ram. how can i tell this is really a 2GB ram. without opening it ? How the hell do i open it anyway ?Last edited by giglife; 05 March 2015, 21:04.
Hi there,
i have the m8 2gb with the roundish remote and I use the S82 image 5.0.3 ,
I thing it's run smoothly, sec is working so i use my sony tv remote but the original remote does not work.
Is usefull to wok with the original remote bgecause when the standby problem fixed you can power on the device with it.
Originally posted by MikeD View PostUse this version:
This is build for M8 and your remote should work with it.
With the s82 version the device works perfect except the rc which is not so problem because of sec and I prefer that. I wnder if I could replace the "remote.conf" file from the m8 version, will it works?
You could use original remote.conf from the stock firmware (or from M8 openelec) and place it in /storage/.conf. Then this will load on every booting and you can use your RC with openelec. But you won't be able to boot the box with your original remote because that is fixed to a remote in every build and can't be changed.
Try updating to the M8 version by placing the update.tar in /storage/update and reboot. Maybe that works without freezes.
There are currently 4223 users online. 0 members and 4223 guests.
