OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by d3ft View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostIt is my understanding that most devices should go through a router or Ethernet switches. I have all my devices going through switches then to the router. I have three 5 port switches in different locations, but only one connection to my router. One of my tuners connect one switch, and the other tuner to a different switch. From my understanding, connecting the tuner directly to your box will not work.
Given my router is in a different room to my aerial, I'd much prefer to hardwire it rather than have to stream the feed over wifi.
Originally posted by d3ft View PostHmm that is interesting. My current Windows based setup has the HDHR plugged in directly using a MediaPortal back-end and works perfectly through XBMC. Is there some reasoning behind why you think it should be run through the router?
I will almost bet you will see your tuner in the config page on your browser.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
woohoo made it thrpugh one full movie an hour 37 minutes no reboots ill keep testing so far so good s82 5.0 on mx iii working
Originally posted by xoexpireu View Postloaded s82 5.0 running it now keeping fingers crossed
Originally posted by xoexpireu View Postmade it through one full movie firat time in a long time and it recognizes wifi so far so good s82 5.0 on mx iii working good so far ill keep testing.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI have read that before but don't recall where. I am old and my memory is not very good. If your router is in a different room, how do you get internet to your computer? One way to verify if plugging directly into your box is the problem, disconnect the Ethernet from your box and do your setup using WiFi. Just remember your WiFi connection will have a different IP address.
Can the S89 running OpenELEC not assign an IP address perhaps? Seems a bit weird.
Originally posted by d3ft View PostMy current setup is a Win7 box running MediaPortal backend and XBMC front-end. The tuner is connected directly via ethernet while I get internet via wifi. I see no reason why I shouldn't be able to recreate this setup on my S89, except replacing MediaPortal with TVHeadend.
Can the S89 running OpenELEC not assign an IP address perhaps? Seems a bit weird.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If you want to use the tuner directly connected to your backend both ip addresses have to be in the same range (e.g. 192.168.1.*). I don't have a hdhomerun but that is the normal case for communication in networks.
But when you use WiFi on openelec you can't manually set an ip address for your wired connection, right?
Hi guys,
I got an MXQ S85 from Gearbest a few days ago.
My case looks different from the pics on their website, it's all matte, not shiny at all. New revision?
Only used it very briefly with stock firmware (seemed to work okay), now flashed this amlinux.ru image:
I'm having a few issues though, can you guys confirm this is 'normal' at this point, or am I facing a hardware defect?
Also tried to post in xbmc.ru forums, but did not get a registration mail, so only read access for me
Issues:
- When playing BluRay over network, I'm getting a black screen for a split second, a few times per minute. Only for the video playing, OSD is still visible. MKV/h264 don't have this issue.
- XBMC framerate (pressing o) varies all the time from like 17 to 34fps; movie seems to look okay though.
- CEC is very flaky and stops working completely after a while, this seems to be a known issues.
- Ethernet failed completely when i left the box running over night. reboot brought it back.
- I had audio dropouts when watching a movie, like a few seconds sound, then a few seconds not; or stuttering. This even continued after a reboot, after leaving the box idle for like 20min, i could watch a whole 90min movie without problems. I thought this could be an overheating issue, but at least according to the temp. sensor the box stays quite cool during playback:
MXQ:~ # cat /sys/devices/virtual/thermal/thermal_zone0/temp
46
At the moment it seems fine, having a little crackling noise sometimes, but no dropouts.
I read some boxes have issues with badly soldered HDMI connector, could this be it? The video does not drop out though.
- Optical SPDIF does not seem to work at all, even though dmesg would suggest so, no sound out of there. It works fine in Android.
I've read a few post but not clear if anyone got original remote to power box on?
I've read a few post but not clear if anyone got original remote to power box on? I have my remote working for everything else but does not power the unit back on after powered off. I know this was asked before but I didnt see any real answers or how to do it?
MX iii working much better now with S82 5.0
I did leave a live stream on today before I left for work and powered tv off when I had my wife check it three hours later live stream stopped box had screen saver on dimmed and was unresponsive had to unplug power and back on not sure if there is a fix for that but thought i'd put it out there.
Thankz
Originally posted by xoexpireu View PostI've read a few post but not clear if anyone got original remote to power box on? I have my remote working for everything else but does not power the unit back on after powered off. I know this was asked before but I didnt see any real answers or how to do it?
ThankzMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
left it on overnight with live stream running. Checked it in morning stream was no loner playing but
Originally posted by clarkss12 View PostI am using my S89H as a stand alone DVR so I leave it powered on all the time. If I change sources while it is streaming a TV channel then come back to it, it is still streaming that live TV channel. It never freezes or locks up. I am also running OpenELEC 5.0. The stock remote will power it on and off.
Thankz
Need Openelec for MXIII 2g
Hey everyone, need help. I have MXIII box with 2gb ram. Looking for latest OpenELEC for my box. I'm running on 112k4 firmware. Everything seems to be fine, except from time to time XBMC reset itself to the default. That's why I'm looking to flush this box with different firmware. Can someone point me to the right place? Thank you.
Originally posted by clarkss12 View PostThat could be the reason, not really sure. But if you verify that it will see your tuner by WiFi, then you can go from there.
Originally posted by d3ft View PostI updated the firmware on my HDHR and have gotten TVheadend to see it through the web interface (connected via ethernet to the S89). Unfortunately, all the setup guides appear to be for an older version of Tvheadend as mine looks completely different. I've tried to get it to scan channels but it just sits there saying "PENDING".
There are currently 8829 users online. 3 members and 8826 guests.
