OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by razdolbaev View PostIn 5.0.3 i remove CEC option in menu, because is not working properly.
Originally posted by noosk View PostThanks for the amazing rom, it works perfectly on my MXIII 2g. Which MXQ model does this firmware support? Is it the one that looks like the MX2 or the one with the hardware button?
any chance to have the tv remote wake up the box from standby through cec? In that way we can hide the amlogic device behind the tv or similar!
Cec settngs like raspberry
Originally posted by Condorello View PostUpgraded to 5.0.3 and works fine, thanks! That linux rom make these box the perfect htpc!
Please can someone add cec setting like the one that are used in a raspberry to our amlogic devices. See picture.
I think that a lot of people need something like that.
Hello guys, got a noobie question for you.
I want to update my Tronsmart Vega S89 / Orbsmart S82 to openelec. I went to http://amlinux.ru/image/5.0.3/ and downloaded "OpenELEC-Amlogic.S82.arm-5.0.3.zip"
The flash is successful but during boot I only get a black screen after the tronsmart logo.
Am I using the wrong file? I thougt S82.arm stands for Orbsmart S82 & the .tar file is for updating an existing openelec. (I am still on Stanes AMLinux )
Sorry if this has been asked here before, couldn't find the awnser to my question.
Sincerely Bonzenpaule
Originally posted by MikeD View PostFlash cache and make factory reset after installing the rom.
And yes, you have used the right zip file.
I found a different way to solve my problem.
First I flashed the standard android firmware from orbsmart - then openelec 5.0.0 and then 5.0.3.
Working great now although openelec 5.0.0 had no bootlogos at all :O (5.0.3 is fine)
But I will do that factory reset can't harm
Cheers!
original remote
If anyone is interested i have modified the keyboard.xml to allow the original remote to play, pause and stop as well as bring up the shutdown menu.
1=Play
2=Pause
3=Stop
0=Shutdown menu
This file needs to be placed in the /storage/.kodi/userdata/keymaps folder and a reboot done.
I have done this on my MXIII 2G using the S82 openelec
rename file from .txt to .xmlAttached Files
Something really strange happened, I am using OpenELEC 5.0.3 on my Vega S89H with tvheadend installed. As I was watching a live TV stream a SMS text message popped up in the lower corner of my TV screen. My granddaughter had texted me a message to my cell phone. The message was right there on the TV screen. I had been using mighty text to send and receive text messages right from my TV when I had Android installed. Is it possible that when I installed OpenELEC it did not erase the underlying Android addons, and if so how can they still function?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2798 users online. 1 members and 2797 guests.
