OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by roolmapool View PostI confirm... much more stable than others release.
It rocks!
Thanks a lot, finally I reached the stability my wife is able to use! :-)
Updated without problem. I've two MX-III 2g box, same software (this) same tv and same cable. One box seems to have a refresh problem. Image blinks at the beginning of the playing or when in live-tv i've a minimized channel and i'm scrolling the channel list. I'll put a video for a better understood.
JustMe thanks again for your works, any news about the CEC after the wakeup?
Re: OpenELEC for s82, M8, MXIII, Tronsmart S89
Originally posted by Condorello View PostUpdated without problem. I've two MX-III 2g box, same software (this) same tv and same cable. One box seems to have a refresh problem. Image blinks at the beginning of the playing or when in live-tv i've a minimized channel and i'm scrolling the channel list. I'll put a video for a better understood.
Originally posted by ccadi View PostRunning well here on S89, but when I turn tv off S89 goes into standby, never done that before. If I take it out of standby it switches tv on. Can't find a setting to stop this.
echo 0 > /sys/class/amhdmitx/amhdmitx0/cec_config
Put it in the file .config/autostart.sh so it is run on boot
don't forgot exec command chmod +x autostart.sh
Maybe there's another way, but not familiar at the moment.
No ethernet connexion
Hello,
I tried to install the OpenELEC-Amlogic.S82.arm-4.97.1.zip in my S89H box.
Everything work fine but the Ethernet link isn't.
I cannot get a valid Ethernet connection, I always get an wrong IP address. It should be in range 192.168.0.x and I always get an 169.254.30.x address.
It work fine with WiFi connection. I also tried with a S89 elite and I have the same issue.
Because I used those boxes with android before in the the same network I had to change the Mac address because of the conflict as described there: http://www.freaktab.com/showthread.p...ega-S89-series maybe it could be the reason why.
Am i the only one with this trouble? Is someone know how to fix that?
Thanks in advance
Petitdroud
sorry for my bad English
There are currently 1818 users online. 0 members and 1818 guests.
