[Pipo Project] M6 Pro
    I've created this thread for discussion of the M6 Pro ROM.
    A few months ago, Pipo entrusted me with the source code to their discontinued RK3188 tablets. Our team of developers has been hard at work making at least one last firmware version to address as many of the problems that were left behind when Pipo's development stopped.
    Here's Maakie's M6 Pro test ROM:
    Here is v1.0 of the FreaktabROM:
    I took Maakie's firmware with d33's kernel and added:
    Autoinstall
    Boot Animation by Tatty
    Busybox
    Rooted with Koushik's Superuser
    Added things to the ROM kit I've always added
    Added TWRP recovery to install after first boot
    Google Play Store fixes
    Some Build Prop Tweaks
    Added Multi-user Support
    Added a bunch of parameter files
    Added the First Time User's Guide
    Download
    Here is the updated version from Maakie v1.1:
    Download
    Thanks to Maakie's efforts, we now have v1.2:
    Wifi Version
    3G Version
    Please read the threads about the changes in v1.2 and report your findings after flashing.
    v1.1 was missing the First Time User's Guide, but I did include it in v1.2.
    Enjoy and don't forget to donate to the developer of your choice.
    Randy
    Maakie, I've flashed your ROM and it runs very smooth. I've got an Antutu score of 22843 with complete stock configuration.
    Can you post a list of the changes you've made to the kernel/ROM?
    As soon as Tatty gets us some boot screens, I can do the usual RileyROM stuff.
    Rooting, Init.d, Busybox, Autoinstall.....
    So far, a really good firmware!!!!!!!
    Randy
      I have only made some small changes apart from modifying it for M6Pro hardware
      ROM:
      Enabled SD display mode
      Enabled multiuser
      Enabled quicksettings tiles for user, 3g and location
      Enabled rotation in launcher
      Kernel:
      Added Hotplug governor
      There is a problem with playing video files in SD mode which will be fixed in next version.
      Please report any other issues you may find.
        A few Questions :
        - is this an AOSP Rom built straight from googles source ?
        - which version is it ?
        - if it's built from source , is lollipop possible ?
        I read some guides on how to build AOSP for any device
        and found out that you need the vendors device config
        in order to build a ROM. Did Pipo give you their sources for
        the M6Pro , too ? Every Guide I read was missing the part where it explained how to use or where to put the vendor files. I want to learn how to port or build ROMs from source but can't find anything that goes beyond the point of setting up the build environment.
        Gesendet von meinem M6Pro mit Tapatalk
          Re: [Pipo Project] M6 Pro
          These ROMs are being adapted from M8HD firmware sources provided to us from Pipo. We aren't allowed to share them, sorry.
          I imagine that 5.0 might be a remote possibility...but no promises right now.
          Sent from my P1 using Tapatalk
          Randy
            this rom very good, fast and smooth. just one question,how to root it.
              Originally posted by GZD View Post
              how to root it.
              Kingo Android Root, Root Genius, VRoot cаn help you.
                Guys,
                This is a test rom, Randy will do his magic after we have been confirmed all is OK.
                So, please be kind to test it and give us your report of what is not working.
                Here is a simple test protocol :
                - LCD
                - Touchscreen
                - Audio
                - Rotation
                - WIFI
                - Bluetooth
                - Camera (Photo / video)
                - 3G
                - GPS
                - audio (micro, headphone)
                - Automatic Brightness
                - Sensors (use App like Z device to test compass, gravity, Light sensor etc)
                Advanced functions:
                - Hot spot Wifi
                - Wifi Direct
                - Bluetooth Tethering
                - Bluetooth audio
                - Bluetooth send files (in/out)
                - Bluetooth BLE (low energy)
                - Ethernet
                - HDMI
                - USB tethering
                - VPN
                - MIRACAST
                - Deep sleep (Tablet Wifi only or 3G)
                - USB OTG
                - USB OTG with hub
                - USB Audio with external DAC
                - Network shares : CIFS, NFS
                App related functions
                - Google agenda synchro
                - Exchange
                - Rotation for Based Launcher
                - external Sd writing Pb : QuickOffice for example
                Extra functions
                - root
                - init.d support
                - overclocking kernel
                If I forgot some , add them !
                  I will try it as soon as I can and report any bugs.
                  Is Pipo willing to give you M6Pro Sources too ?
                  Offtopic : Where did you guys learn to build ROMs from source ? Especially the part with hardware drivers etc.
                  I know how to build android for emulator , but want to learn how its done for real devices with real Hardware.
                    http://www.freak-tab.de/maakie/PipoM6Pro_ROM_141031.zip
                    Hallo! Do You have plan to port the CM on pipo m6 pro?
                    I has PC with Linux (Mint 17) and my CPU is Intel i5 4440. I can help to you to make the ROM if you tell me how i can do it. I can test the ROM also.
                      After two days use. this rom is stable and fast. Almost all fuctions work which include miracast. That is really good because the tablet reboot all the time before if i use it. But one thing Gps not working even could not find device .
                        Thanks for the report.
                        As soon as Tattman65 gets some boot screens ready, I will provide a rooted version.
                        Let's also see if we can get GPS working.
                        Sent from my P9
                        Randy
                          one more problem.hdmi output not stable .it will stop for a second every minutes.
                            Any chance for a M6 Max (3g) Version?
                            Cheers from Switzerland
                            Galaxy Note 3 : stock (4.4.2) ROM
                            Cubot GT99 : stock ROM with crossbreeder
                            Pipo M6 3g : FreaktabROM v1.0.0
                              Here is a new version of the ROM with better GPS reception and improved performance:
