[Pipo Project] M6 Pro
    Pipo_M6Pro_FreaktabROM_1.0, first impression
    I took Maakie's firmware with d33's kernel and added:
    Autoinstall
    Boot Animation by Tatty
    Busybox
    Rooted with Koushik's Superuser
    Added things to the ROM kit I've always added
    Added TWRP recovery to install after first boot
    Google Play Store fixes
    Some Build Prop Tweaks
    Added Multi-user Support
    Added a bunch of parameter files
    Added the First Time User's Guide
    Download
    I've tested it on my M6
    Hi all, my first impression: GOOD!
    Install was quick and easy, a few remarks about this version:
    After install, and the first reboot I got a Google services halted, Google play service need update.
    It started installing Google Play Services v6.1.
    After my restore of Apps and Data the Google mail widget I had on my homescreen was not working. (I use KK launcher)
    After remove of the widget I could not add it again, because it was not in the list of available widgets.
    I installed the Google mail app again, after that the widget was available again and I could add it to my homescreen.
    AnTuTu again in the 24400-24800 range. Happy!!
    I will keep you posted about how my apps are behaving.
    Un saludo,
    Satbeginner
      After a reboot, I'm starting to see deep sleep
      Sent from my M6Pro using Tapatalk
        Deep Sleep after ( second) reboot
        I can confirm, Deep Sleep starts working after second boot.
        So, directly after flashing, deep sleep does not work, but after the second boot, it does.
        My M6Pro does the same.
        Un saludo,
        Satbeginner
          Everything sounds good so far.
          The new ROM is working great on my M6 Pro.
          Please report anything you find that needs some tweaking.
          Has anyone tried GPS?
          Randy
            Re: [Pipo Project] M6 Pro
            GPS working good here. First time after installing I got a fix in 90 seconds. After running gpsfix app and rebooting, I now get a fix in about 30 seconds.
              Now that you have more to work with, I want to report a chronic bug that is also present in Riley ROM 1.8.
              There are certain Web sites that will always crash with the stock browser in this rom. I don't actually use the stock browser, but using it as a way to present this bug is easier. The app I actually have the problem with is greader, an rss reader that has a function to display a Web page.
              I use rss readers a lot, and this bug is so irritating, because the workaround requires you to constantly switch back and forth between the reader and the chrome browser.
              To recreate an example of this bug, open the stock browser and go to
              The Braves' President of Baseball Operations doesn't believe that the Braves will be able to extend Jason Heyward before he hits the free agent market.
              The browser will crash. Most browsers will crash on this rom with that Web site. However, the Google Chrome browser will load it.
              I also tried this site with the stock browser on the 4.4.2 stock rom on my Samsung Galaxy tab pro and it loads fine. It also loads fine with the stock browser on cm11 on my phone.
              The logcat shows Chromium Web view errors.
              Here is an excerpt, I can send the entire log if it is helpful. I think google has stopped updating Web view, but the version in these pipo roms must be different in some way from cm11 and the latest Samsung stock roms.
              The logcat excerpt :
              11-11 18:57:21.836 448 925 I ActivityManager: START u0 {act=com.android.systemui.recent.action.TOGGLE_REC ENTS flg=0x10800000 cmp=com.android.systemui/.recent.RecentsActivity (has extras)} from pid 613
              11-11 18:57:22.176 121 121 E hwcomposer: dstStride[416] < [2048 + 0 + 0]
              11-11 18:57:22.176 2682 2682 W IInputConnectionWrapper: showStatusIcon on inactive InputConnection
              11-11 18:57:31.106 2888 2888 E browser : Console: Blocked a frame with origin "http://nym1.ib.adnxs.com" from accessing a frame with origin "http://www.talkingchop.com". Protocols, domains, and ports must match. :0
              11-11 18:57:31.116 2888 2888 E browser : Console: Blocked a frame with origin "http://nym1.ib.adnxs.com" from accessing a frame with origin "http://www.talkingchop.com". Protocols, domains, and ports must match. :0
              11-11 18:57:35.486 2888 2925 F libc : Fatal signal 11 (SIGSEGV) at 0xffffffff (code=1), thread 2925 (android.browser)
              11-11 18:57:35.586 119 119 I DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
              11-11 18:57:35.586 119 119 I DEBUG : Build fingerprint: 'rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.metaxyn.20141108.161041:eng/test-keys'
              11-11 18:57:35.586 119 119 I DEBUG : Revision: '0'
              11-11 18:57:35.586 119 119 I DEBUG : pid: 2888, tid: 2925, name: android.browser >>> com.android.browser <<<
              11-11 18:57:35.586 119 119 I DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr ffffffff
              11-11 18:57:35.706 119 119 I DEBUG : r0 ffffffff r1 b26b4700 r2 ffffffe9 r3 ffffffff
              11-11 18:57:35.706 119 119 I DEBUG : r4 404ec800 r5 4052cc11 r6 f2be03bd r7 ffffff1a
              11-11 18:57:35.706 119 119 I DEBUG : r8 ffffffe9 r9 ffffffff sl 40526471 fp 7ede6690
              11-11 18:57:35.706 119 119 I DEBUG : ip 00000000 sp 776775a8 lr 40526487 pc 404ec81c cpsr a0000010
              11-11 18:57:35.706 119 119 I DEBUG : d0 0000000000000000 d1 0000000000000000
              11-11 18:57:35.706 119 119 I DEBUG : d2 0000000000000000 d3 0000000000000000
              11-11 18:57:35.706 119 119 I DEBUG : d4 4517400000000974 d5 c40ac000fffffdd5
              11-11 18:57:35.706 119 119 I DEBUG : d6 00000873440ac000 d7 000000003f800000
              11-11 18:57:35.706 119 119 I DEBUG : d8 41c8000000000000 d9 438db70000000000
              11-11 18:57:35.706 119 119 I DEBUG : d10 c080000041700000 d11 0000000000000000
              11-11 18:57:35.706 119 119 I DEBUG : d12 0000000000000000 d13 0000000000000000
              11-11 18:57:35.706 119 119 I DEBUG : d14 0000000000000000 d15 0000000000000000
              11-11 18:57:35.706 119 119 I DEBUG : d16 ffffe91a0d0d0d00 d17 ffffffffffccff47
              11-11 18:57:35.706 119 119 I DEBUG : d18 ffffffffbd52bd6b d19 fffffffff240f2b2
              11-11 18:57:35.706 119 119 I DEBUG : d20 edffdc0d0d000d00 d21 76ffbdccff00cc47
              11-11 18:57:35.706 119 119 I DEBUG : d22 67ffd252bd00526b d23 77ffff40f20040b2
              11-11 18:57:35.706 119 119 I DEBUG : d24 ffdc0d0d000d0000 d25 ffbdccff00cc4700
              11-11 18:57:35.706 119 119 I DEBUG : d26 ffd252bd00526b00 d27 ffff40f20040b200
              11-11 18:57:35.706 119 119 I DEBUG : d28 3ff1745d20000000 d29 4008000000000000
              11-11 18:57:35.706 119 119 I DEBUG : d30 0000000000000000 d31 3ff0000000000000
              11-11 18:57:35.706 119 119 I DEBUG : scr 6a000013
              11-11 18:57:35.706 119 119 I DEBUG : backtrace:
              11-11 18:57:35.706 119 119 I DEBUG : #00 pc 0008c81c /system/lib/libskia.so
              11-11 18:57:35.706 119 119 I DEBUG : #01 pc 000c6485 /system/lib/libskia.so (SkColorShader::shadeSpan(int, int, unsigned int*, int)+20)
              11-11 18:57:35.706 119 119 I DEBUG : #02 pc 0009a3f3 /system/lib/libskia.so (SkARGB32_Shader_Blitter::blitMask(SkMask const&, SkIRect const&)+172)
              11-11 18:57:35.716 119 119 I DEBUG : #03 pc 000a6983 /system/lib/libskia.so
              11-11 18:57:35.716 119 119 I DEBUG : #04 pc 000a6b4d /system/lib/libskia.so
              11-11 18:57:35.716 119 119 I DEBUG : #05 pc 000a5c51 /system/lib/libskia.so (SkDraw::drawPosText(char const*, unsigned int, float const*, float, int, SkPaint const&) const+376)
              11-11 18:57:35.716 119 119 I DEBUG : #06 pc 0009e573 /system/lib/libskia.so (SkCanvas::drawPosText(void const*, unsigned int, SkPoint const*, SkPaint const&)+118)
              11-11 18:57:35.716 119 119 I DEBUG : #07 pc 004c652f /system/lib/libwebviewchromium.so
                Use uc browser which I always use
                to view the site no problem. But it does crash when use stock browser.
                  Only one thing, I wish the strength of the wifi signal could be increased? Had some problems with strength and speed of wifi. 5 meters away from router and only 1 bar, if lucky 2 and veeery slow speed. Removing The aluminium back and replacing it with one made of plastic solved the speed problem. Fast speed even though only 1 or 2 bars. Is it possible to make some kind og tweak in this rom to strengthen the wifi signal?
                    GPS OK in v1.0
                    Hi all, I can confirm GPS is working when used with Sygic navigation.
                    Will check compass direction (N<>S) later.
                    Un saludo,
                    Satbeginner
                      Yeah, I know a few browsers work. But the RSS readers I use (especially Feedly, greader), don't display some pages within the app without crashing, I believe because the version of chromium web view built into this rom is either in need of an update, or somehow broken. Getting the RSS apps to work correctly is my main goal. I just used the stock browser in the example because it also uses chromium web view, and it is easier to recreate.
                        wi fi not function
                        Hi, unfortunately after installing the rom 1.0 freaktab, it does not activate the wifi and the bluethoot it, what do I do?
                          Wifi and bluetooth working fine here.
                          Maybe you got a bad download or a bad flash.
                          The md5 value I get for the file is:
                          285f346269e45614a2248620ecb38e23 pipo_m6pro_freaktabrom_1.0.zip
                          If you don't have that for your file, maybe try again until you do.
                            wi fi not function
                            The same thing happens to me? Anybody know why??
                            I flash it 2 times
                              wi fi
                              I have already flashed twice, erase, but nothing. Still not working. I downloaded the version of rrileypm. You give me another version in case. Thanks.
                                Where do I see the MD5 value? Thanks.
