Rom 1.0 runs perfect but its freezing on my tablet. 10 minutes at the most before freeze. Tried kernel from first release, but it did not do the trick. It's 10 minutes, if lucky, and a freeze. I have a very unlucky cpu as no oc kernels has ever worked without problems. RR 1.8.2 runs ok with no major problems. Is the kernels in these two new roms (maakies first and 1.0) oc? The new rom feel snappier so i would love to have this working.
[Pipo Project] M6 Pro
freeze
WORKS GREAT
I came from RR KK 1.8.1 with OC kernel 1.7CPU/stock GPU/800MEM and I must say : NOTICEABLE faster now with stock settings !
Wifi : ok
Sound : ok
GPS : ok (althow i dont use it)
Batt life : in my case : better then before
All my apps restored from Titanium backup : everything works. Not a single problem !
Wifi only M6Pro with 16Gb.
Antutu 24611 in HD mode and 25126 in normal mode.(i keep mine in normal mode... even more responsive and screen is more then good enough for me)
Tablet is faster than ever before !
Only thing i want to get rid off is that ugly anoying google searchbar on top of my screen.
And oh yeah : the boot screen is simply beautifull
Cudos to the devs for all the work !!!
Pipo2000: xposed gel can remove the Google search bar....
Love this ROM, you guys are awesome! Coming from RR1.8, this is snappier.... Similar scores as posted, xposed works, apps from my backup work... Lots...
I have not used mirror screen.... But I want to mirror... I have a chromecast but one app that I am having trouble with is the new app "mirror" exits after trying to connect to the chromecast device (using all cast and all cast receiver) and ideas to get that combo to work? (Chromecast) what device has been tested to cast to? Thanks!
Sent from my M6Pro using Tapatalk
Re: [Pipo Project] M6 Pro
Originally posted by Ayscii View PostPipo2000: xposed gel can remove the Google search bar....
Originally posted by artaz View PostHey guys, I tried everything ( with 3G chip)whit out 3g chip restart the tablet but no wifi alls.Are there anyone who has the 3G version with working wifi?
How to change HD mode for normal mode?
Somebody tested miracast with ezcast single?
Originally posted by sonicvfa View PostOn my tablet at beginning , WiFi doesnt work...then i restart with a 3g chip....and WiFi works.....bit if i turn off the WiFi it doesnt work anymore...for it works, i need to do the same thing... Restart with 3g chip...i believe the problemas is in the libril file, but the good thing is the deep sleep that now works....
There are currently 2326 users online. 0 members and 2326 guests.
