[Pipo Project] M6 Pro
My first freeze with v1.1freaktab rom
Hi all,
I just had my first freeze, I had to do the pin-reset, after which I was able to reboot normally.
Question 1: is there a way of finding out (the next time) which program was running at the time?
Question 2: This time I left my M6Pro not charging this night, because it still had 40% left.
Now the battery is down to 26%.
Could the freeze be related to a lower battery voltage? If so, is there a way of increasing the cpu voltages just a bit to avoid this?
I will install 'the alternative kernel' to test with that as well.
I will keep you posted, un saludo,
Satbeginner
Originally posted by lecksmatt View PostThis is KitKat rom right? I'm currently using RR 1.8.2 KitKat and if i want to install this custom rom, should i tick the Loader or not?
I had no problems doing it like this.
Un saludo,
Satbeginner
It's the same loader. No problem checking it or not unless you are upgrading from JB.
You might be able to run a logcat after a freeze and see what happened.Randy
Custom kernels from giouncino - is it possible?
Hello to everybody. I'm new to this forum. Recently i bought my Pipo M6 Pro tablet. I tried Dmr48's firmware from 4pda.ru. That firmware is based on RileyROM 1.8.2 with some customisation. On this firmware I did experiments for combination with custom kernels from giouncino and kernel_GPS_1.4_cpu1704h_VERY_LOW_V1_gpu600_ddr744. img was very good for me: fast and stable. . In this combination my tablet take in Antutu 5.2 score 26692. Now I've flashed FreaktabROM v1.1. It's working good, some previous problems go away (like buggy video in Skype) but as for me on overclocked kernel from giouncino the tablet was faster. So i want to ask: is it possible to use a custom kernel version 1.4 from giouncino with FreaktabROM v1.1? If no, is it possible to make custom overclocked kernel with same clock parameters for FreaktabROM v1.1. Thank you for answers.
The most significant fixes to this firmware was done inside the kernel. I'm afraid you would loose some of the fixes by flashing back to the older OC kernel...but it should boot and run just fine. You would just have some of the old problems previously encountered...that's all.Randy
In this case is it possible to add this clock frequencies for CPU and RAM to new kernel? For example 216-1704 MHz for CPU & 744 MHz for RAM like it was in giouncino kernels
I will have to let the kernel guys answer that.Randy
Works Smooooth, except for these 2 games?!
So far, everything is working great! When I tried to install the 2 'Rayman' games (and the obb files) it crashes and says can't start.. I've tried every version I can find on the web (about 4 for Jungle and 2 for Fiesta). Any ideas?! I like to use them to show off the graphics for my friends I'm building for..
(4.2.2 works with them, of course) Also, not using ART, if it matters.
-Thanks!
try this
Originally posted by sleepums View PostSo far, everything is working great! When I tried to install the 2 'Rayman' games (and the obb files) it crashes and says can't start.. I've tried every version I can find on the web (about 4 for Jungle and 2 for Fiesta). Any ideas?! I like to use them to show off the graphics for my friends I'm building for..
-Thanks!
Anyone having problems with game freezing, ie Boom beach etc. Here's the solution I found on another forum. Tick “Disable HW overlays” under the Developer options in settings and games work fine.
There are currently 1877 users online. 1 members and 1876 guests.
