[Pipo Project] M6 Pro
    Aging with 1.8.2
    Originally posted by spd08 View Post
    Hello
    I have always used Riley 1.8.2 and i had to reflash it often because of "aging", that means things were going worse with time
    just discovered about this new rom, i will ask for help if something doesn't work, i'll try it in the next days
    but still THANKS for your work!
    I had to reboot every now-and-then with RR1.8.2 too, although it worked fine.
    Now I use the v1.1 ROM, but with the kernel using the Stock settings, and -for me- this is the best.
    All the basics just work, no slowing down, no sleep-of-death, I do not feel the need to reboot or reflash at all, it just works.
    Un saludo from Spain,
    Satbeginner
      Input lag
      Originally posted by lecksmatt View Post
      Yes i did but still the problem is visible. What i mean about my problem is that when i type fast, sometimes my touch isn't recognized. When i'm typing fast, i tested it again, i typed literally fast on RR 1.8.2, they're all recognized by the screen. I really don't know where is this problem coming from but AFAIK, the touch is within the kernel right?
      EDIT: Now i can clearly see that it's kinda lagging, for a second or 0.5 second it stopped and stuck then runs again.
      Have you tried setting the screen resolution from "HD" to "Normal" ?
      My touch input is only lagging in "HD" mode and when i switch it to "Normal" everything works perfect as it should.
      I think the device (cpu too weak, kernel settings wrong etc.) isn't handling the input right when in "HD" mode.
      I don't know if it was asked before, but does the camera not work with version 1.1 ?
        flashed
        I report the following
        • when i rotate the screen (portrait) the google search bar on the launcher goes outside the screen, it doesn't get resized, anyone else?
        • after the first boot i got an error, a process had stopped, but it never happened again, so it's no big deal
        • now aparted and link2sd have trobules in creating and recognizing ext2 partition. aparted doesn't create successfully ext2 partitions anymore, so link2sd fails. riley 1.8.2 was ok on this
        • recovery mode apparently doesn't work. there's just an icon but i can't do anything
          Did you try flashing the included TWRP_Recovery.img? Just flash it separately with everything else unchecked in the flash tool. Don't erase IDB.
          Randy
            there's no such file
              Just download this one:
              Randy
                ok!
                twrp flashed and working, sd card could be formatted as well
                the rom seems to run smoothly and has also less issues to handle many installed apps
                but why the impossibility to format with aparted with ext2/3/4 (fat 32 works, and with 1.8.2 it worked also ext2)?
                precisely i do this
                -full format sd on settings, memory
                -unmount sd
                -go on aparted
                -create two partitions, fat32 and ext2/3/4
                -fat32 completes
                -ext2 doesn't say "format complete", instead it formats (apparently) but afterwards aparted doesn't see the card anymore, and link2sd doesn't see it as well formatted, because it can't mount it. once the tablet rebooted while formatting, another time it just didn't to anything (but again, only on ext2)
                creating two fat32 partitions works smooth
                the sd is also not damaged, since i could format it with twrp, as said, and now works fine
                and about the google search bar?
                  I'm not sure...we need to ask Maakie about the search bar and EXT2.
                  Randy
                    yes it would be nice
                    i described a bit better what i did
                      The kernel doesn't have support for EXT2.
                      The width of the search bar is probably some variable in Launcher which can be changed.
                      I'd planned to release a new version with some fixes.
                        It may be possible to include in the new ROM Enabling SMS.
                        Thank you very much.
                          and can the kernel get the support?.... in the previous one it was implemented
                          additionally to the lenght of the search bar, the icons close to the app menu (in the downside of the main launcher screen) are a bit "compressed". it's just a visual thing, but since there's space.....
                          also, the digital clock is not centered
                          as said, no big deals, just "nice to have"
                          one more thing i just noticed
                          gps test always show "no fix", even if it sees satellites, like agps is not functioning
                          another gps test app finds my position right (without satellites), but google maps can't find me, it says just "waiting for position", like there's some sync error
                          and this with the high precision method
                          antenna is not the best so i've always relied on the google location service
                          this had already been reported
                            What about security fixes?
                            I would like to direct the focus on the question "who is going to fix security issues in the Pipo firmware?":
                            I installed the bluebox security scanner on my Pipo M6 Pro (Firmware v1.1) and noticed, that the firmware is vulnerable to the Android Bug #136778484, also called "FakeID" (more info here: https://bluebox.com/technical/androi...vulnerability/ , http://www.zdnet.com/article/google-...security-hole/ ) .
                            So my question is:
                            Who is going to fix that vulnerability and implement the google fix into the firmware?
                            Kind Regards,
                            TM
                              Based on the articles I've read, this bug shouldn't be present in Android 4.4.2...which is the version this ROM is based on. If you have updated your Google Play Services, it's my understanding that the problem should be fixed. Otherwise, I'm not sure what else you would like us to do.
                              Randy
                                So my question is:
                                Kind Regards,
                                TM
                                According to the links you gave, this bug is not present in kitkat, which is what this rom is based on. Maybe you are getting a false positive.
                                As to the bigger picture, I raised this question earlier. It is highly unlikely that Pipo (or any other Chinese vendor ) will update firmware for security reasons. They expect you to buy a new tablet if you want updated firmware.
                                To be fair to the Chinese vendors, I would expect that the vast majority of devices referenced in that article will never be fixed.
                                Randy and his team now have source code for a few models. Whether or not that would let them do security updates is unknown.
                                Sent from my SM-T520 using Tapatalk
