[Pipo Project] M6 Pro
    Originally posted by stevejc View Post
    Hi, I have made a modified kernel with stock voltage :
    you can find here https://mega.co.nz/#!pdkWnYwJ!EyM1Xj...eLoog1y-T0ThKE
    It works well for FatFreddyDK who has the same problem
    Maybe the kernel has some others differences with Maakie's one.
    Hi stevejc,
    I have installed your kernel for over an hour, everything works fine, no freesing, no newstarts, no troubles.
    Only one funny thing, now wifi works only, when I have a Sim cart inside, but thats not a problem.
    Thank you for your fast help, it´s great.
      Originally posted by ivo.siebi View Post
      Hi stevejc,
      Maakie will repost new kernel later, because he had made some new changes and DDR frequency that I have been using may confict with GPS.
        Stevejc here are some explanation:
        DDR at 528Mz:
        2° modulation intefere with GPS (at 1575Mhz)
        DDR at 720Mhz:
        2° modulation interfere with 3G (at 2100Mhz)
        DDR that are working properly:
        768Mhz is always OK
        DDR 600 and 667 may works without interferences too
        all these frequency doesn't need overvoltages (1.2 - 1.25V are sufficient)
          DDR at 528Mz:
          DDR at 720Mhz:
          768Mhz is always OK
          Thanks for your explanations
            charging, not working
            double post, sorry !
              The M6 Pro doesn't charge via USB...not enough voltage from a USB port. You have to use the stock charger. None of the M series tablets charge with USB (maybe the M7 Pro...I can't remember).
              Thanks Randy that was my bad, i knew that because i always charged it with the original adapter, i think i was overwhelmed by the excitement of this great rom that is flawless in my case (M6 pro no 3G) that i forgot that my other devices are Samsung usb charged, but not my PiPo !
              Thanks for your time & devotion as well as to D33/Stevejc/Maakie for this [Pipo Project] M6 Pro , before this i was considering giving up on my tablet and now i am really enjoying it !!!
              Ivan.
                Hey D33/Stevejc/Maakie...I have one little tweak that I think would be a major improvement...but it needs some testing.
                On the M6 Pro, the speaker volume has never been loud enough. I've solved this by using Viper4Android and it works quite well. I've never been able to find that one setting in the system files to turn it up. Can you look in the kernel code and see if there's anything that can be done to boost speaker volume?
                It really wouldn't hurt to turn it up a notch or two on each of the devices. I played around with my M7 Pro using Viper4Android and while stock volume is listenable...it could stand to be louder too. I haven't even played audio on my new M8HD yet to see if it needs it.
                My P1 has the same form factor as the M6 Pro...and it too has this pesky volume problem...again solved with Viper4Android until maybe we get sources for it someday?
                Thanks!!!!!!!!!
                Randy
                  this result cannot be compared with the tests we did with my modded kernels months ago, because, as you can see, Antutu 3D test has been changed and you can see the biggest improvement in points there... so to have a good performance comparison, you need to do an antutu test (version 5.2.0) with older ROM with my modded kernel.
                  Apart from benchmarks I'm sure that maakie's rom is fantastic and is for SURE better than all roms built by Pipo during almost 1 year of development!
                  @giouncino, I was curious about this as well, since Version 5 of Antutu does yield different (higher) results to Version 4.
                  So I installed version 4.5.1 of Antutu and ran against this rom and got 20523. This is just the stock kernel with no modifications and OC's, and it is about the same as the best I got with your tweaked kernels. And I still have had no reboots or SOD's !
                  Sorry you sold your M6Pro before this ROM came out, you could have had some fun with it I'm sure
                    I agree, it's a very good result for a stock kernel on m6pro! I'm happy for the "new life" of your devices.
                    Some friends of mine still have the pipo m6prp, I suggested them to install it!
                    (in reality I'm happier with my new tablet now!).
                      R: [Pipo Project] M6 Pro
                      Model? What is better? Performance? Audio?
                      Inviato dal mio SM-G900F utilizzando Tapatalk
                        Thank you.
                        Originally posted by FatFreddyDK View Post
                        Rom 1.0 runs perfect but its freezing on my tablet. 10 minutes at the most before freeze. Tried kernel from first release, but it did not do the trick. It's 10 minutes, if lucky, and a freeze. I have a very unlucky cpu as no oc kernels has ever worked without problems. RR 1.8.2 runs ok with no major problems. Is the kernels in these two new roms (maakies first and 1.0) oc? The new rom feel snappier so i would love to have this working.
                        Just wants to let you know. All problems with my m6 pro wifi only has gone away. Kernel provided by Stevejc solved it all. Running 2 days now with no hick ups, freezing pr reboots. Thanks to you guys i will stay with pipo.
                          ROM v1.0, after I changed from Dalvik to ART, about 50% of my apps keep getting optimized?
                          Hi all,
                          although my M6Pro runs great with the v1.0 ROM!! , I am still testing to see if it can be improved further. One recent change I made was changing from Dalvik to Art.
                          The result? Some apps would crash upon starting the app, so these apps are obviously not up to date or capable to run with Art. I removed these apps for further testing with the rest of my apps.
                          All the rest is running fine, but after every reboot about 50% of my apps is getting optimized again.
                          After this, everything is working great again.
                          Any suggestions?
                            Originally posted by Satbeginner View Post
                            Hi all,
                            Any suggestions?
                            Yes you need Gapps uptodated
                            FatFreddyDK has done the same and here what he told me
                            His optimizing app problem at every reboot was solved by intalling new gapps from here : https://www.androidfilehost.com/?fid=95784891001608846
                            Install thought TWRP and you need to do a wipe cache
                            Maybe we will add this in future ROM
                              ROM v1.0, after I updated GAPPS, perfect, no more apps getting optimized at reboot when using Art!
                              Hi SteveJc, hi all, this is how I installed GAPSS from .ZIP file.
                              First,shutdown the M6Pro by holding down the Power-On button, choose Shutdown.
                              Then, reboot the M6Pro while holding the Vol+ and Back button and Power-On button.
                              When it is starting, release the Power-On button, then release the other two buttons as well.
                              The M6Pro will now boot into TWRP recovery.
                              Choose INSTALL, and select the location of the downloaded GAPPS.ZIP file (in my case the external SD-card), and Swipe from left to Right to install the ZIP-file
                              If everything goes OK, it will report "Successful"
                              Now tap the "Wipe Cache/Dalvik", and Swipe from left to Right to perform the Wipe.
                              If everything goes OK, it will report "Succesful"
                              Tap "Back", then tap "Reboot System"
                              The first time it will optimize all installed apps. (133 in my case....)
                              After this quite a few of the newly installed Google Apps came with a Not Responding message. Probably because the system was very busy, in all cases I choose "Wait"
                              The first full reboot took about 15 minutes!!, so be patient, including updating both Hangouts and Google+.
                              As a test I performed a reboot again, this went OK, no optimizing anymore!!
                              Thank for the quick and good advice!!
                              Un saludo from Spain,
                              Satbeginner
                                On the PipoM6Pro_ROM_141109 I can't get a root. I don't see SuperSU. What Can I Do? Thank You
