[Pipo Project] M6 Pro
Originally posted by maakie View Post
Originally posted by FatFreddyDK View PostWould it possible to get a kernel with same speed/voltage specs as in the kernel provided in rr 1.8.2? (Only one thats worked for me entirely without reboots and freezes). With 1.0 rom the tablet runs better than ever exept for random freezes and reboots. Even miracast works.
Thanks for this Rom! Flashed it yesterday, Antutu scores through the ceiling (24000+).
However, when I compare wifi speed with my Mipad, difference of day and night: Mipad 16 Mbps, Pipo +-1 Mbps... They sat next to eachotherTested with Speedtest from Ookla, same server...
Anyone else with the same issue?
Tested Riley's build of maakie firmware and d33 kernel on my tablet: M6 Pro (3G)
LCD - OK
Touchscreen - OK
Audio - OK
Rotation - OK
Camera (Photo / video) - OK
WIFI - Not Working (Logcat reports driver issues (Driver Not Ready messages))
If you turn on Wi-Fi, it throws a bunch of driver errors in Logcat and turns itself off.
Bluetooth - Not Working
Driver errors in Logcat turns itself off when enabled.
[Can't test 3G because my SIM card gets stuck inside, so I just don't use the feature.]
The kernel is really really fast, but there seem to be some driver issues on my tablet.
I have installed this Rom in my pipo m6 pro 16/WiFi. I have never enjoyed my tablet like this since I got it. It is so much more snappy and responsive. I am not an expert to test it in detail just an average user. For me one big step is the lack of the sudden death that made the tablet go off and needed to press the reset button on the back , to boot up again. :-)
Στάλθηκε από το M6Pro μου χρησιμοποιώντας Tapatalk
v1.0 is a new ROM, but with 'standard' settings
Originally posted by annaepi View PostI wonder one thing. why do not I have the option of deep sleep and the maximum frequency is 1608 MHz? Before I came to 1704 MHz. Thanks.
I found that this ROM (with its standard settings) is very stable, and even without changing CPU frequencies, it is faster than the previous ROM's.
Deep Sleep does work, but you need to reboot again after the first boot.
After the first boot, the installation process finishes and cleans up the installation.
If you than reboot the tablet again, all the settings are final, and Deep Sleep will work.
My guess is, that as soon as you start messing with the CPU settings, you may loose stability....
Un saludo,
Satbeginner
Originally posted by kryo View PostTested Riley's build of maakie firmware and d33 kernel on my tablet: M6 Pro (3G)
LCD - OK
Touchscreen - OK
Audio - OK
Rotation - OK
Read the name on the back cover of the tablet.
The GPS is working? (if not present, you have an m6 NON pro)if you appreciate my efforts this is the link for any donation:
Originally posted by Satbeginner View PostThe v1.0 ROM is a new build from sources ROM. With your previous ROM you probably used a different kernel that had changed CPU settings, and possibly also changed memory parameters.
Un saludo,
Satbeginner
There are currently 2805 users online. 0 members and 2805 guests.
