WeTek Play - AML-8726 MX
    OK i saw some feedback and their forum and i decide buy one Hope get it soon....
    BR
      BR
      I hope you will be lucky as me, received mine in 2 days
        Hi Nakata and taki somebody can test oscam implementation this I'm curious about result http://www.FreakTab.com/showthread.php?t=21140
          Many cams could work (gbox, mgcamd, cccam, oscam) with openelec, mgcamd needs some extra file (/usr/lib/libcrypto.1.0.0) to work properly (maybe a static build of libcrypto could work too), to get good oscam functionality the kernel should include pl2303.ko, usbserial.ko sio.ko etc...
          You can run softcams for other cortex a9 boxes like prismcube...
          Best regards!
            Best regards!
            On 4pda forum some guy tested and posted photos. I used google translate to translate link posted by eltorodroid.
            Guy there says it works perfect and time to open encrypted channel is from 1 to 3 seconds depending if he zapp channels on same frequency or on different frequency.
            Can somebody explain me what i need to test this tool. I installed this .apk and with ps -x command i see new process called oscam running and also I am able to open app from APPS menu and there is option to insert username and password for server, also web interface works.
              hmm, you have to know the config-files:
              at minimum you need
              Code:
              oscam.conf
              oscam.server
              oscam.user
              lines (external server) would be handled at the oscam.server as [reader]
              e.g. to connect to a cccam-server (c-line)
              Code:
              [reader]
              label = cccam
              protocol = cccam
              device = <[I]IP[/I]>,<[I]port[/I]>
              account = <[I]username[/I]>,<[I]password[/I]>
              emmcache = 1,1,2
              detect = CD
              Group = 1
              caid = [I]x,y,z,....[/I]
              You can also use a domain instead of IP
              RK3288 Devices
              - Overview BOX (LINK !)
                Hi
                i've got vigica c60s , this box have same specs ( aml 8726mx , same tuner avl6211 av2012 )
                i really want use openelec , can you tell me if i can try your version with my box ?
                there is a link of the product
                  I doubt it will work... You will probably kill your box, vigica uboot will not be supported.
                    Originally posted by freddy_krueger View Post
                    Hi
                    http://www.vigica.cc/products/uk-mar...roid-4.2..html
                    hey, wetek soft work only on their box, not other work, so relax.
                    «Сомалійська Наноелектроника та Космонавтика»
                    1. VS-IP015 - Android Sat Receiver - g18ref_th2
                    2. WeTek Play - Android Sat Receiver - g18ref
                      Hate when ****ers in china use openSource and makes it closed source. People creating opensource projects for years and here comes china, copy all and then ask money for it
                      me too have vigica which is the same Wetek and i want to use Wetek soft which is NOT theirs on vigica. Will try my best to make it work
                      NEVER believe in chinese promises.
                        good luck amigo!
                        only WeTek until damp, try spark2
                        if want openelec try that:
                        Openelec VITMOD 1.5-alfa for the VS-IP015, the image under the SD card
                        - Base Openelec 5.0.x, kodi 15 alfa1, kernel 10/03/61
                        - Tvheadend HTSP Client 2.1.1
                          Err, I have to correct you
                          WeTek is not Chinese company, thats first. And all sources you need is available in OpenELEC official github repository as WeTek is officially supported by OpenELEC.
                          If you find my work useful, buy me a beer
                          Homepage: http://www.stane1983.com
                            This you should ask Vigica... why not work with Openelec, Wetek makes their work complaining with all open source, making partnership with all (kodi and Openelec) and you come were and ask why they don't make support for Vigica a GPL violator? Serious?
                              Oh please Wetek do shit. WHat they made? NOTHING. Everything they use is made by someone else years ago. Im not saying Vigica is better just saying that everything WETEK uses is opensource.
                              Not first time when china uses opensource but hides the sources.
                                They do Nothing.. so why you want to port their sw to your Vigica
