WeTek Play - AML-8726 MX
Originally posted by iam View PostAs your brain compared to mineWetek is a clone of vigica, vigica is a clone of another box...all they the same. God damn. Difference is only that Wetek spends money on commercial.
WeTek - 5 x USB | Vigica - 2/3 USB
WeTek - Bluetooth 4.0 | Vigica - No
WeTek - DDR 3 at 1333 MHz | Vigica (1033 MHz)
WeTek - 4 GB Samsung NAND Flash | Vigica
WeTek - WeTek OS, CM, AOSP, AOKP, OMNI ROM, OpenELEC, OpenPCTV, Ubuntu, Android TV | Vigica - Factory Android only
WeTek - Plug & Play DVB Tuners | Vigica - Single fixed tuner
WeTek - DVBI-API supported | Vigica - AML TV API
WeTek - Native Linux apps | Vigica - AML TV apps
WeTek - WeCloud services | Vigica - NONE
WeTek - Easy Upgrade/Rescue | Vigica - NONE
WeTek - RS-232 Serial & Cable | Vigica - NONE
WeTek - WeControl Android virtual RCU | Vigica - NONE
WeTek - AirMouse RCU | Vigica - IR basic RCU
WeTek - Cheap price | Vigica - For what offers EXPENSIVE
Originally posted by freddy_krueger View PostGuru , please stop this unmature reaction, you seem like a kid
wetek is not super megar hyper mega box
same hardware as vs_ip015 or vigica , only difference is community
and maybe wetek play can run openelen , but vigica for example don't need to add any plugin to use cccam
not like wetek that need to install tvheadend + oscam plugin or ostool
so please stop your kid comments
Insert usb, click at apk, install, start app, configure and go under android adn watch in Wetek theater
WeTek cannot be compared to any other box at the moment. I had the R89(was a week old) and a Dreambox 800HD; combine the prices and compare it with WeTek Play's price. My dreambox version could only do 1080i and the R89 with all the powerful GPU(8-cores), CPU(Quad core at 1.8Hz) I was still not happy with the 1080p@60Hz output - micro stuttering, even SD videos on some apps had problems. I mean, I read in other forums how they are having problems with the ones that have 8-cores CPU. You can make it 100-cores, if the firmware is not solid you cannot have a good experience.
I replaced both of the boxes with my WeTek play - sold them last week and I have not regretted it.
I can't wait for the next version of Play - will surely have a bit more power to run Lollipop UI better.
On CH11 OSCam is already installed, you only need to use the browser *:8888 to configure it.
Originally posted by droidelec View PostWeTek - 5 x USB | Vigica - 2/3 USB
Originally posted by droidelec View PostWeTek - Bluetooth 4.0 | Vigica - NoEarphones?
Originally posted by droidelec View PostWeTek - DDR 3 at 1333 MHz | Vigica (1033 MHz)
Originally posted by droidelec View PostWeTek - 4 GB Samsung NAND Flash | Vigica
Originally posted by droidelec View PostWeTek - WeTek OS, CM, AOSP, AOKP, OMNI ROM, OpenELEC, OpenPCTV, Ubuntu, Android TV | Vigica - Factory Android only
Originally posted by droidelec View PostWeTek - Plug & Play DVB Tuners | Vigica - Single fixed tuner
Originally posted by droidelec View PostWeTek - DVBI-API supported | Vigica - AML TV APIOriginally posted by droidelec View PostWeTek - Native Linux apps | Vigica - AML TV apps
Originally posted by droidelec View PostWeTek - WeCloud services | Vigica - NONE
Originally posted by droidelec View PostWeTek - Easy Upgrade/Rescue | Vigica - NONE
Originally posted by droidelec View PostWeTek - RS-232 Serial & Cable | Vigica - NONENice money spent Wetek
D Dumb noobs debuging Wetek bugs and making free fixes and they (byers) even pay for doing job for wetek
Originally posted by droidelec View PostWeTek - WeControl Android virtual RCU | Vigica - NONE
Originally posted by droidelec View PostWeTek - Cheap price | Vigica - For what offers EXPENSIVENEVER believe in chinese promises.
Well why you then ask for WeTek software to load at VigicaKeep enjoy with no-support device as Vigica is
Who needs bluetooth in such device? what you connect to it?Earphones?
Costs 2x less and does absolutelly all the same. Shows tv, have xbmc, have TVHEADEND..runs all android apps.... i see 0 difference
Originally posted by iam View PostVigica is easier. you only need to put files to microsd and reboot tuner - no button pushing and so on. You also can update from android gui.
Originally posted by iam View PostWhat do you talking here? Wetek and Vigica are the same cpu. so what wetek can - vigica can too., for more info start reading DVB-API at linuxtv.org , but hey, no worry, Vigica will never deliver DVB-API so you are stuck with no native support of DVB-API v5.
Originally posted by iam View PostOpenELEC runs on vigica too. From MicroSD, Nand - other sare the same shit with different name.. But hey WeTek sponsor of Kodi Project http://kodi.tv/xbmc-sponsor-page/ , heey http://openelec.tv/news/21-partners/...or-of-openelec
And finally, WeTek care about other users:
Such shameiam is crying for months here at forum as WeTek don't want to publish any software for Vigica, and still saying Vigica is good
Btw. did you try Android TV or Android Lollipop 5.0?
P.S:
Ahhh I forgot you are running on Vigica, sorry will not ask again
There are currently 1245 users online. 0 members and 1245 guests.
