TWRP for minix x6, tv110, Beelink s85 and Acemax MXQ
Originally posted by daemonium View PostHi, i did a port from abdul's twrp, so all the credit must go to him.
Here is the 4 twrp's zip pack
https://mega.co.nz/#!NV9GRCJa!Fs8jUn...wBDdmVTG9BSngY
And Spanish instrucctions are here
http://androidpc.es/blog/2014/11/23/...-mxq-y-tv-110/
Note: Only mouse works, physicall keyboards doesn't work. So ensure to have a mouse connected.
This method loads the TWRP from sdcard, it doesn't flash it. So when you reboot and pull your sdcard , TWRP will be gone and your original recovery will be there. If someone wants to flash it, just ask for it and i will provide a zip.
For english users:
- Download the zip pack from above
- Prepare a microsd or SD card (acording to your tvbox's) with fat32 format
- Copy the recovery.img for your tvbox to the sdcard's root filesystem
- Insert sdcard
- Turn on the tvbox while holding the reset button
- twrp must show up, the image doesn't fill the screen, this is ok because it's made for compatibility, you can flash one of abdul's twrp themes to fit your screen. You can find them in abdul's twrp thread for Amlogic M8 tvbox.
Special note for Tv110 users and for the ones that doesn't have reset button.
1) If your box is rooted, install petrus's reboot app (or similar) , insertd sdcard and do reboot recovery from the reboot app.
2) If your box is not rooted, you can fool the box. Create a empty txt file just like "rom.txt", rename to "rom.zip", copy it on sdcard beside recovery.img (twrp), run OTA UPDATER from the box and select the zip from sdcard, run update. TWRP will show up and give you an error about rom.zip (that's normal because it's not really a rom ), you are done.
I'm using this with the Acemax MXQ (no power button on top).
I did notice however that it will boot from the SD card, but not recognize the External SD Card once TWRP opens. So I've been storing my backups on a USB (which does mount in TWRP).
Can you please take a look to see if you can fix the SD card access in TWRP for this model?
Can I help you by uploading the stock firmware's recovery? (or maybe that was the problem originally? haha)
Thanks so much!!
Much Appreciated!!
Originally posted by maosales View PostHey daemonium! Thanks for the awesome port.
Thanks so much!!
Much Appreciated!!There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by daemonium View Posti plan to update twrp to the latest 2.8.4, stay tuned.
Quick Question, I'm a big fan of your CWM for the G18Ref / mx2 variants, mainly because it does the entire data folder, while TWRP doesn't.
Any chance of a port for any of the S802/S805 M8/M8N/MX3 variants?
Thanks!!
Thanks!!There are 10 types of people in the world: Those who understand binary, and those who don't...
yup, updates are planned.There are 10 types of people in the world: Those who understand binary, and those who don't...
Updated first post with newer versions. I will be out for a week, if there's something wrong please post it here and use the old version until i come back. ThanksThere are 10 types of people in the world: Those who understand binary, and those who don't...
download not working.
Originally posted by daemonium View PostUpdated first post with newer versions. I will be out for a week, if there's something wrong please post it here and use the old version until i come back. Thanks
Originally posted by vn800art View PostHappy holydays! Or maybe you will be at MWC?
Thanks a lot, will try.
Alessandro
Inviato dal mio Nexus 5 utilizzando TapatalkThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by vn800art View PostGood luck and easy recovery for You, I recommend to Developer's Gods!
There are currently 1724 users online. 2 members and 1722 guests.
