TWRP for minix x6, tv110, Beelink s85 and Acemax MXQ
Originally posted by vn800art View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Just had a go with the newer versions (TV110 .img) on my Sumvision Cyclone x4 with OpenELEC 5.0.6 installed.
2.8.5.1 just leaves me with a stripy screen.
2.8.5.0 boots into TWRP fine but the only partition I can mount is the external SD which I assume is also why Backup fails as no partitions are listed.
2.8.1.0 works well other than it's not full screen on the TV, I assume it's the same one that bobones reported to be working ok earlier in the thread but can't be sure.
EDIT: The file from the first post labeled as 2.8.4.0 works fine, it reports the version as 2.8.1.0 which is why I was confusion.Last edited by 312BhP; 18 March 2015, 23:29.
Originally posted by 312BhP View PostJust had a go with the newer versions (TV110 .img) on my Sumvision Cyclone x4 with OpenELEC 5.0.6 installed.
EDIT: The file from the first post labeled as 2.8.4.0 works fine, it reports the version as 2.8.1.0 which is why I was confusion.There are 10 types of people in the world: Those who understand binary, and those who don't...
hi guys
I have a black mxq that will not boot into recovery
I can still flash the box from sd card but it wont go in to recovery with command line, apps or tootpick methods just reboots into os
my thoughts are by installing twrp.zip that this may fix my issues?
the box runs fine just unable to boot recovery
Daemonium could you please pm me the zip to flash
many thanks
fozLast edited by foz; 07 April 2015, 10:20.
many thanks
fozThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Post
Sure, please provide a link to your original firmware, there are different mxq versions out there.
link below is stock firmware
do you think this should fix my problem? or do you think I need an .img flashed via pc to get recovery back working ?
https://mega.co.nz/#!UkgHHIra!gb6tQO...oUu0YzdfCyQMXQ
i noticed also if I boot into bootloader it just boots in to the os also
Many thanksLast edited by foz; 14 April 2015, 08:22.
Originally posted by foz View Postfinally fixed my mxq recovery, just using the twrp on sd card and restoring a back up, but if when you get chance can I please still have the zip
massive thanks
foz
Updated to 2.8.6.0 , see the OPThere are 10 types of people in the world: Those who understand binary, and those who don't...
Thanks daemonium, the TV110 build seems to work ok on my Sumvision Cyclone Android x4 running OpenELEC 5.0.6
I just created a backup with it and now the GUI is full screen.There are 10 types of people in the world: Those who understand binary, and those who don't...
First post updated with newer versions. Now the backup is full, even internal sdcard is backed up.
Guys, is there some special trick to restoring a twrp backup? I have MXQ HD18Q, I made a full backup using the latest twrp recovery for it, so I could flash back to the stock rom if I didn't like the one I was going to flash. Now, it seems whenever i flash back the stock twrp backup the device goes into some kind of bootloop where the mxq logo flashes and disappears, the device doesn't boot up anymore. I can get into the twrp recovery no problem, however, it's not properly restoring the image. I have to flash the new firmware which works fine, but that firmware has issues with ethernet and wifi getting randomly disconnected. Please help on how I can restore my backup. I really need to flash back the stock rom.
There are currently 2565 users online. 2 members and 2563 guests.
