TWRP for minix x6, tv110, Beelink s85 and Acemax MXQ
    Great!
    Inviato dal mio Nexus 5 utilizzando Tapatalk
      Patches to the source code
      Thank you so much for your port to Acemax - works like a charm!
      I was wondering if you have or could make your patches to TeamWin's GitHub code available? It is pretty much the only available SD-card recovery boot code for Acemax that I know of and it could help other projects.
        let me get some info on how to do that
        There are 10 types of people in the world: Those who understand binary, and those who don't...
        If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
          Version 2.8.4.0 worked fine.
          Version 2.8.5.0
          Beelink s85 MxQ
          Picture over-scan / enlarged (1080) .
          Think needs to be 720.
            Version 2.8.5.0
            Beelink s85 MxQ
            [ATTACH=CONFIG]10749[/ATTACH]
            if i'm not wrong that's solved on 2.8.5.1, let me have a look and prepare it
              Cheers daemonium
                Cheers daemonium
                Can you try this one?
                twrp 2.8.5.1 Beelink mxq (s85)
                  ... twrp 2.8.5.1 Beelink mxq (s85), now all i`m getting is blue screen.
                  No need to spend too much time, 2.8.5.0 works just fine.
                  thanks
                    https://mega.co.nz/#!vQRnBTAS!L6827m...E7EFTPccTd_Wy8
                    Would this work from USB memory i do not have sdcard slot.
                    i do have an S805 tvbox rooted.
                      this is not a generic twrp, so i can't say it will work.
                        thanks
                        thanks for the feedback, i will take a deeper look.
                          thank you for your answer.
                          Every post for mxq s85 or any other tv-box regarding installation is from sd-card so
                          i ment was if it would install from usb-stick instead of sdcard if it was the right box?
                            Yesterday evening was definitely not the right one. No booting from sd on Mxq s85 and neither on MXIII Plus ( this from Abdul in another thread) ! I forgot how to do it? Getting too old?
                              do you need help?
                                Not now! Bed time. Sorry I didn't see your kind message earlier! Will think about it tomorrow, cheers @Daemonium!
