Note: Only mouse works, physical keyboards doesn't work. So ensure to have a mouse connected.
This method loads the TWRP from sdcard, it doesn't flash it. So when you reboot and pull your sdcard , TWRP will be gone and your original recovery will be there. If someone wants to flash it, just ask for it and i will provide a zip.
For english users:
- Download the zip pack from above
- Prepare a microsd or SD card (acording to your tvbox's) with fat32 format
- Copy the recovery.img for your tvbox to the sdcard's root filesystem
- Insert sdcard
- Turn on the tvbox while holding the reset button
- twrp must show up, the image doesn't fill the screen, this is ok because it's made for compatibility, you can flash one of abdul's twrp themes to fit your screen. You can find them in abdul's twrp thread for Amlogic M8 tvbox.
1) If your box is rooted, install petrus's reboot app (or similar) , insertd sdcard and do reboot recovery from the reboot app.
2) If your box is not rooted, you can fool the box. Create a empty txt file just like "rom.txt", rename to "rom.zip", copy it on sdcard beside recovery.img (twrp), run OTA UPDATER from the box and select the zip from sdcard, run update. TWRP will show up and give you an error about rom.zip (that's normal because it's not really a rom ), you are done.
I can't try all of them since i don't have all this tvbox, so don't flash it, just try it from sdcard. If something doesn't work please report it here. Thanks.
Version 2.8.7.0 [based on official twrp for k200 developed by Abdul_pt] ** This is the newest **
Changelog
- Initial ground work for software drawn keyboard (_that)
- Fix handling of wiping internal storage on datamedia devices (xuefer)
- Allow DataManager to set and read values from the system properties (xuefer)
- Fix crash when taking screenshots on arm64 devices (xuefer)
- Fix error message after an ORS script completes (Dees_Troy)
- Fix crashes / error when creating encrypted backups (_that, Dees_Troy)
- Add system read only option – more details below (Dees_Troy)
- Add resize2fs and GUI option to run resize2fs (Dees_Troy)
- Fix crash loop caused by empty lines in AOSP recovery command file (_that)
- Prevent duplicate page overlays such as multiple lock screens (mdmower)
Beelink s85 - https://mega.co.nz/#!SRQ0mIYZ!DcE4g2...aCoc32A7xkhShs
Acemax MxQ - https://mega.co.nz/#!SZoG1aJT!p61ttR...XvalS-BSJtIY9g
Minix x6 - https://mega.co.nz/#!HAYFmC6b!SxGDMi...n7W_RJa5DdC_0E
Version 2.8.6.0-2 . [based on official twrp for k200 developed by Abdul_pt] ** old **
Changelog
- Backup of Data will backup InternalSD also, it will only skip TWRP and Downloads folder from internalSD.
- There will be no entry in backup menu for internalSD
- On restore it will NOT wipe internalSD, but overwrite it. So anything newer/different than the backup will be maintained.
Beelink s85 - https://mega.co.nz/#!DU5zDTwD!nBTbu8...EypJPFC6AlXLGo
Acemax MxQ - https://mega.co.nz/#!LZZHgAoI!-RWfC3...yWvCEHhmTu4JPs
Minix x6 - https://mega.co.nz/#!yJAylALD!VenKJs...5C3XERL89 L5sY
Version 2.8.6.0 [based on official twrp for k200 developed by Abdul_pt ] **old**
Dropped support for minix x6. If anybody asks for it i will add support again.
Tv110 - https://mega.co.nz/#!bN4CwTSb!5xARzr...M-0vvSjdvqzcRw
Beelink s85 - https://mega.co.nz/#!KIYXQJRQ!0c3Imv...TAHi1PhW0KbJCY
Acemax MxQ - https://mega.co.nz/#!yYoGQaTR!wyjd6z...BKXfWLGH67P4Dc
Version 2.8.5.1 [Auto resolution is bugged, use 2.8.6.0 instead] [based on official twrp for k200 developed by Abdul_pt ] **old**
Minix x6 - https://mega.co.nz/#!TQJRhCCQ!-42D09...DNqyDXiySHIOIQ
Tv110 - https://mega.co.nz/#!DIgRQAZZ!K6FxdQ...gMHcP55nZgEmPE
Beelink s85 - https://mega.co.nz/#!vQRnBTAS!L6827m...E7EFTPccTd_Wy8
Acemax MxQ - https://mega.co.nz/#!vRomWDrL!jd6-yt...kM2JvVZF_gFASM
Version 2.8.5.0 [based on official twrp for k200 developed by Abdul_pt ] **old**
Minix x6 - https://mega.co.nz/#!LVpX0aDa!3A1xlM...7kWLw9sQ-cFSxs
Tv110 - https://mega.co.nz/#!eAJxDDiD!eGM5yG...DbnDSfIWHQBCCE
Beelink s85 MxQ - https://mega.co.nz/#!qMZHHDDZ!_yKi_E...mDhviTAMuHbKqY
Acemax MxQ - https://mega.co.nz/#!SVACEI6B!AW4Bo3...S8wBnpxYXeBVsA
Version 2.8.4.0 **old**
https://mega.co.nz/#!NV9GRCJa!Fs8jUn...wBDdmVTG9BSngY
And Spanish instrucctions are here
http://androidpc.es/blog/2014/11/23/...-mxq-y-tv-110/
