Alternative Flash Method
    You don't have to flash the box via your PC, USB cable, reset button and Phoenix Suite.
    You can also a) write the stock factory image to an SD card with PhoenixCard V309, b) insert the SD card and then power cycle the box. It'll boot the image and flash it straight to nand memory. No cable, no reset required.
    Image to SD card = 7 - 8 minutes
    SD card to nand memory = 8 minutes
    Not the fastest route, perhaps, but avoids possible issues with drivers, USB and the burning tool.
    I've uploaded PhoenixCard here (new link):
    The link below summarizes this "Production SD Card Method". Just make sure the "Product" option is checked before writing the image to SD card.
    The tools, drivers and Android image for Arches (pcDuino8 beta) can be downloaded from: http://www.linksprite.com/?page_id=861  There are two ways to re-flash the image: a production SD card method and OTG method.   1. Production S ...
    Note: with our board, you do get a helpful on-screen progress bar during the flashing stage.
    I've uploaded PhoenixCard here:
    https://mega.co.nz/#!8IF3xSBD!i7Cbo8Kh-LKqxMKLPSTZ2ypSKCbuqynwqDctHnZ_d6c
    Very cool!
    I am sticking this!
    I could not get the BRAIN DEAD stock recovery to use update.zip files. I kept getting some sys mount error.
    So this is the next best thing!
    Also I have a new TWRP recovery ready... I will be uploading it soon.
      A small find, inspired - as always - by your great discoveries, Bob.
      (Can I take down my upload?)
        Why? Do you want me to move the download to the FT server or something?
          It's not a big deal, Bob, it can stay where it is.
            Either way my friend just let me know. If your trying to save space on your mega account I certainly can post the download here. Whatever works best for you.
              Link updated
                (New) link back up in my original post.
                  I put this on the FreakTab server as a mirror.
                    well done I forgot about that one , I used that method for the a10's i have 2 sitting here which i bought while back , but have not used due to me being novice back then forgot to save teh remote conf and lost the ir remote , i did post on forum while back but never got any repliers for the XYTV A15 player with a10 which i would still like a remote ir fiel for it still
                    well done Zahir, I think you have many hidden talents not exposed yet just like Finless
                    Bugs are Sons of Glitches!
                    JustMe
                      actually to be honest thats how i discovered freaktab 1.5 years ago due to that issue
                      JustMe
                        It depends on the card:
                        ADATA Premier microSDHC Class 10 UHS-I U1 8GB
                        Code:
                        USB2.0-HUB-Reader (Spec Version 2.00)
                        CrystalDiskMark 3.0.1
                                   Sequential Read :    18.465 MB/s
                                  Sequential Write :    12.368 MB/s
                        PC => 2:30
                        Draco => 3:05
                        I don't know what's the bottleneck but seems to be a 'Spec Version 2.00' reader at the Draco...
                        RK3288 Devices
                        - Overview BOX (LINK !)
                          Good to know it can be speeded up. Not sure I'd invest in a super-duper SD card for the occasional flash, but others very well may.
                            We're all very happy you did find your way here - for whatever reason.
                              Excellent
                              Excellent find Zahir
                              Finless 1.1 only a couple of minutes to Create
                              about same amount of time to Write to Draco with progress bar
                              Thank You
