Alternative Flash Method
    Don't get anything larger than 32GB SDcard! Larger wont work as it cannot be formatted FAT32 and has to be formatted EXTFAT or NTFS.
    Bob,
    SUCCESS! SUCCESS! SUCCESS!
    Thank you and the thread guru for all your help!
    My TELOS is back from the dead and working 100% - with Finless 1.1 Beta!
    Here is exactly my setup for the SD Card method of updating the "dead" Draco:
    Windows 8.1 64 Bit PC
    Sandisk Extreme Plus SDHC UHS-I Card *(80MB/s designed for the demands of 4K UHD Video)
    Insignia Multi-Format USB 3.0 Card Reader Model NS-CR20A1
    Card and reader were purchased at local BestBuy store.
    The writing of your ROM with Phoenix Tools 3.09 went like glass!
    It wrote from the card in about 90 seconds and the Draco powered down, I rebooted, and all is perfect!
    One bit of help, which version of XBMC can be recommended?
    Again, thanks for all the hand-holding as I "went nuts" yesterday.
    Cheers,
    Gary
      stock rom flash failing
      Hello guys
      I have burned the stock rom to SD card and tried to flash it 3 times, each time the progress bar stops at about 2/5 the way, and I wait for 15 minutes, but it does not go further.
      Any ideas?
      I assume the SD burn was fine, since it said it was fine...
      Any clues?
      tx
      Mark
      _________________________________________
      Out: USB audio, HDMI
      In: Logitech K400 keyboards
        @140Hours, glad to see you're up and running finally.
        Looks like we can dub the SD card method the Lazarus method...
        For XBMC, I use TVMC (the best Gotham 13.2 performance I've found) or Helix RC3 (fast, but some fav addons don't quite work yet).
        @Mark, try another SD card. Yours may have completed the write stage but may still have an unreadable sector or two.
        If you don't have another card handy, use the 'format to normal' option in Phoenix card to restore your card to standard format, then write the rom to it again.
        A slow card as basic as my Transcend HC 8gb works every time.
          Thanks... what worked, oddly, was reformatting the SD card and burning the image again... this time it completed the operation. Very strange. I guess the Phoenix burn success message is not entirely true!
          cheers mate
          Mark
            Originally posted by DiZet View Post
            ... I get all the success messages but when I check the cards they are empty. ...
            Originally posted by no_spam_for_me View Post
            FYI, no need to place the img at the partition, because PhoenixCard (v3.0.9) place it in front of the partition (I think also in front of the MBR) like the SD Card Maker at Amlogic devices (not the whole img but the uboot)...
            => so you can't see it at the SD but you can recognize that the size of the SD decreases...
            To get back the original size you have to reformat it...
            e.g. with
            - HP USB Disk Storage Format Tool 2.2.3
            - SD Formatter https://www.sdcard.org/downloads/formatter_4/
            RK3288 Devices
            - Overview BOX (LINK !)
              => http://www.tomshardware.co.uk/answer...fat-fat32.html
              RK3288 Devices
                Also works:
                32 GB QUMOX 80MB/s Class 10 UHS-I SD *
                Transcend TS-RDF5K (USB 3.0)
                * cheap and fast, specially at QD
                Code:
                CrystalDiskMark 3.0.1 (C) 2007-2010 hiyohiyo
                                           Crystal Dew World : http://crystalmark.info/
                * MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
                           Sequential Read :    83.141 MB/s
                          Sequential Write :    37.997 MB/s
                         Random Read 512KB :    76.374 MB/s
                        Random Write 512KB :    33.183 MB/s
                    Random Read 4KB (QD=1) :     5.274 MB/s [  1287.6 IOPS]
                   Random Write 4KB (QD=1) :     1.050 MB/s [   256.3 IOPS]
                   Random Read 4KB (QD=32) :     6.490 MB/s [  1584.5 IOPS]
                  Random Write 4KB (QD=32) :     1.356 MB/s [   331.0 IOPS]
                  Test : 50 MB [H: 0.0% (0.0/29.9 GB)] (x2)
                I ordered it in hope that we get Linux on/from SD
                RK3288 Devices
                  Did you test guiformat and make sure that Android will still use 64GB SDcard formatted FAT32?
                    no...
                    But I think it isn't a problem to read and write sd > 32GB with FAT32...
                    extFAT is 'only' defined by SD Association (SDA) at sd > 32GB as mandatory feature...
                    => http://en.wikipedia.org/wiki/Secure_Digital#SDXC
                    (somewhere at a German page I read something about that the argument by SDA for extFAT at SDXC was that FAT32 wouldn't be safe/good/stable enough at > 32GB...but come on, who knows, why they really defined it as a mandatory feature???)
                    RK3288 Devices
                      I thought that the MINIX X8 H was meant to be super reliable, at least that's what all the reviews I have seen on YouTube have said. This is not the case?
                        Burn image to SD card on MAC OS
                        Any tool for burning the image to SD with a MAC ?? (I cannot get hold of any Windows machine).
                        I have used terminal but after burning the image successfully the draco does not react to the SD card and boots normally.
                        I use a Sandisk Extreme class 6 4G, formatted to EXTFAT and I get this message after bruning the image
                        1201614+0 records in
                        1201614+0 records out
                        615226368 bytes transferred in 352.150322 secs (1747056 bytes/sec)
                        Thanks!
                          Originally posted by rdaussa View Post
                          Thanks!
                          Your way is not good. Find yourself a Windows PC and follow the instructions on the first page. It's a special way to burn that IMG file on SD card.
                            Try windows using boot camp
                              Livesuite for mac found here: http://dl.cubieboard.org/model/cc-a8...irmware-tools/
                                flash method
                                Iv just flashed finless bobs 1.1 for the Draco to sd card using PhoenixCard v309. The PhoenixCard should be set to product when burning to sd card. so if any thing should happen to the Rom i have on already i just restart my box with the sd card in & boots up with finless 1.1 on my box. It saves have to connect it to a PC when some think goes wrong.
