Alternative Flash Method
Originally posted by frhdt007 View PostRK3288 Devices
- Overview BOX (LINK !)
hello guys, I'm new on this forum and I'd like to say hello to everyone.
Just today I received my draco telos and I tried to flash new finless 1.1 rom and I found some problems. First of all I follow regular flashing method by USB cable but my PC (win7) not recognized draco. I've tried many times pressing FN key and connecting USB wire and no positive resultat. Next one I used alternative way with SD card. I prepared SD card with PHOENIXCARD 3.09 and connected with draco...than I disconnected power plug and connect again with hope that flashing process will start. Unfortunatelly nothing happened...I wait for about 15min and nothing. Blue LED on draco not flash at all, no status bar on screen...nothing. When I removed SD card from draco slot and turn device ON than original tronsmart stock rom appear again. Anybody can help?
When I check SD card it include only one folder LOST.DIR which is empty...is it normal?
PS
sorry for my english it is not my nationality language...
Hi
I would recommand try different SD-Card, had probleme with some, and also with a different SD-card reader if changing SD-Card is not enough, had problem with some also. A 8, 16 or 32 GB should be good enough normally to make it happens. I had the same problem that you have with the usb method, all seems OK driver OK but not recognize by the tools, but managed to flash finless Rom ith SD-Card method
Originally posted by marsini View Posthello guys, I'm new on this forum and I'd like to say hello to everyone.
PS
You should have a successful burning message at the end.
2) insert the SD card in Draco and then power cycle the box. It'll boot and flash .
3) At the end you have to take the sd card out, unplug and plug the power cord to make it boot again .
IMPORTANT NOTE: Just make sure the "Product"; option is checked in PhoenixCard V309 before writing the image to SD card.
thanks for information...I found what was wrong, SD card which I used was probably to slow or something. When I change to new one fast card everything works fine. I have new ROM on my draco.
PS
I thought that finless ROM include METRO UI louncher but it doesn't. Which louncher I should install - which one you guys prefer?
Are These Adapter's safe to flash the Tronsmart Draco AW80 Tellos With
Originally posted by Zahir View PostYou don't have to flash the box via your PC, USB cable, reset button and Phoenix Suite.
You can also a) write the stock factory image to an SD card with PhoenixCard V309, b) insert the SD card and then power cycle the box. It'll boot the image and flash it straight to nand memory. No cable, no reset required.
Image to SD card = 7 - 8 minutes
SD card to nand memory = 8 minutes
Not the fastest route, perhaps, but avoids possible issues with drivers, USB and the burning tool.
I've uploaded PhoenixCard here (new link):
The link below summarizes this "Production SD Card Method". Just make sure the "Product" option is checked before writing the image to SD card.
The tools, drivers and Android image for Arches (pcDuino8 beta) can be downloaded from: http://www.linksprite.com/?page_id=861 There are two ways to re-flash the image: a production SD card method and OTG method. 1. Production S ...
Note: with our board, you do get a helpful on-screen progress bar during the flashing stage.
Originally posted by Android_User5000 View PostHello everyone! i'm new here and just diving into the Android mini-pc/tv box scene. I have a bunch of sd adapters laying around as well as some usb readers and am considering flashing a custom rom to the Tronsmart Draco AW80 Telos. Has anyone tried using any of this type or actually used these exact adapters? Thank you
[ATTACH=CONFIG]9490[/ATTACH]
Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Originally posted by otisrhw View Post... first partition the img to be flashed and second my APK'sRK3288 Devices
Originally posted by ghanashyaml View PostHi Zahir, getting an error loading stock rom image. See attached.
Any idea whats going wrong? I am assuming this works for any image or is this only for Draco?
[ATTACH=CONFIG]9493[/ATTACH]
Originally posted by frhdt007 View PostDid you choose Product option ?Tronsmart Orion R68 Meta
The card method works with the stock rom, Bob's custom roms and the great majority of roms from Pan Baidu.
There are currently 3300 users online. 2 members and 3298 guests.
