Alternative Flash Method
Originally posted by Zahir View PostPhoenixCard puts files on a hidden partition - they're there, just not visible. Insert the SD card in your box and plug in the power cord. Wait at least 7 minutes before removing the card and rebooting.so I have to investigate further.
AW80 USB Driver Not Recognized by Windows 8.1
Unless I'm mistaken, no way the USB driver *INF file provided by Tronsmart for the AW80 is going to be recognized by Windows 8.1.
It just won't load the driver no matter what I try, even manually installing the INF.
So, the SD card method, although I haven't got it to work yet, seems like the only solution for me with Windows 8.1.
Gary
Originally posted by otisrhw View PostYour talking about a bricked box correct? Maybe hardware problem?
Meanwhile, I've had a Popcorn Hour A200 for four years and have NEVER had a single hiccup with it, displaying perfect 1920 X 1080 P BluRay .mkv files in stunning quality.
I'm running out of patience with the Draco AW80 Telos.
Originally posted by 140hours View PostWhy should I have any faith at all in this box? This is the SECOND unit I've had in less than a week, the first one never booted at all, the second (current) one failed after less than twenty four hours, and I can't restore the ROM with USB to PC because PT 3.3.3 crashes every time I try to connect the device in windows 8.1.
The next one, hopefully, will be a keeper for my 4K TV.
Thanks to everyone!
Gary
This is done on windows 8.1 I have done it as well. Not sure what is going on but I have a feeling it's something on your side.
Tronsmart Draco AW80 Firmware Update Tutorial: http://youtu.be/hjaf_-WTJFY
Originally posted by otisrhw View PostThis is done on windows 8.1 I have done it as well. Not sure what is going on but I have a feeling it's something on your side.
Can anyone recommend the items to get that are known to be working well?
Thanks again!
Gary
Don't get anything larger than 32GB SDcard! Larger wont work as it cannot be formatted FAT32 and has to be formatted EXTFAT or NTFS.
Had a few problem with some generic micro-sdcard adapter, and some other with some generic 2 GB sdcard. Same symptom failed after first part of succesfull burn.
I managed to make it work well and fast with a 32GB sdcard Sandisk and/or 32GB microSD (with a Kingston MicroSd To SdCard adapter), and the microSD have even been write on With a MicroSD2USB key. So a 32 GB microSD inside a MicroSD2USB in my PC for flash, then the 32GB microSD (Kingston) in the MicroSD2SDcard (Kingston) adapter.Had problem with bigger then 32GB as not possible to format to Fat32 (as stated by Finless above also)
Once done to recup all space from device use HP format tools, that recovere all space possible from all partition/device (hidden or not).
Originally posted by Finless View PostDon't get anything larger than 32GB SDcard! Larger wont work as it cannot be formatted FAT32 and has to be formatted EXTFAT or NTFS.
I'm trying to use a 64GB Card!
I'll report back after I get a 16GB or 32GB card.
Best wishes,
Gary
There are currently 3944 users online. 0 members and 3944 guests.
