Alternative to Stock Rom
Originally posted by no_spam_for_me View Post2014 12 19_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Originally posted by fredphoesh View Postbut it's sooo last year!?2014 12 19RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostAnd what's about 141025? It's "much more last year"_________________________________________
Best alternative rom so far?
I have the Draco Meta and all I really need to do is stream movie rips/mkv/mp4 files over my network and some web browsing. Weather its MX Player or any version of XBMC or Kodi I get the micro stutter/skipping issue. As of now I have the blurred line at the bottom of the screen with XBMC/Kodi in addition to the afore mentioned. Anyone have any ideas or suggestions for smooth playback? I can stream the same files over wifi to my S4 Phone or Galaxy Tab Pro perfectly so I know its not a network issue as I have the Draco connected directly to my router via ethernet as well as too my PC. Is there a better alternative to Tronsmart based ROM that anyone has tested with the results I'm looking for? Any help is appreciated.
No, it's this one http://www.freaktab.com/showthread.p...ock-20141219v1RK3288 Devices
Originally posted by gokuh82 View PostI have the Draco Meta and all I really need to do is stream movie rips/mkv/mp4 files over my network and some web browsing. Weather its MX Player or any version of XBMC or Kodi I get the micro stutter/skipping issue. As of now I have the blurred line at the bottom of the screen with XBMC/Kodi in addition to the afore mentioned. Anyone have any ideas or suggestions for smooth playback? I can stream the same files over wifi to my S4 Phone or Galaxy Tab Pro perfectly so I know its not a network issue as I have the Draco connected directly to my router via ethernet as well as too my PC. Is there a better alternative to Tronsmart based ROM that anyone has tested with the results I'm looking for? Any help is appreciated.
Try it with TVMC, instead of the official XBMC releases.
Some of us have our eyes (and hopes) pinned on seeing Openelec on our box quite soon: if/when that happens, most, if not all, the video issues that plague the Draco may well be resolved in a fast, efficient Linux build.
Originally posted by BTR11 View PostAs Zahir had said, please try GjayjayG - Homlet V1, It´s the best android rom alternative to the original Meta firmawre (oct/2014). I´m running on Meta and It´s much better than original one and stable. Use no-frills cpu app to set CPU governor to "Performance" and I/O scheduler set to "noop" and I think you will be more or less happy whilst appear the long waited stable update for Android from Tronsmart.
Originally posted by frhdt007 View PostI did what you said and don't see any obvious gain by setting governor to performance and scheduler to noop! Any test to show it?
Any way on the dayli usage me and family feel the overall performance of the box more fluid just navigating between the system, and some lags to play some demanding games, less frequent, even I can feel it playing a simple one, angry birds.
The original no-cpu frills apps settings on the firmware is:
Max clock freq: 1800 Mhz
Min clock freq: 600 Mhz
cpu governor: interactive
i/o scheduler: cfq
The one that I use and where I feel the box respond little better is:
Min clock freq: 1008 Mhz
cpu governor: performance
i/o scheduler: noop
And the box remains stable with not any thermal / overheating problems after hours of use.
Sure more deep test can be run....
Originally posted by BTR11 View PostYes, nothing fancy, please see the pics attached, just to show some numbers. You know the fake antutu line is commented out (#) on this firmware, so this do not affect, and AntutuX v5.1 was not affected as well before. It's a little gain, but given the current level of limitation imposed to the performance of this powerful SoC this litlle gain by original Allwinner SDK ->transferred to the FW, is welcomed; specially this SoC being Octacore you will not see on the current android FW status more than 2 cores working on the Meta version and 3 cores on the Telos version, independent of the CPU governor used.
i/o scheduler: cfq
i/o scheduler: noop
@BTR11
If you have a look at this thread you will see this soc uses more than 2-3 cores if need
and also at http://www.cnx-software.com/2014/11/...oid-4-4-video/
If I'm not wrong we had the same discussion at the past at the Tronsmart forum...
Last but not least the latest kernel at Linux and it's core handling http://www.freaktab.com/showthread.p...l=1#post279857
@frhdt007
Also have a look at the first thread and specially at post #3...
I use 1800 / 1800 MHz....RK3288 Devices
There are currently 3642 users online. 2 members and 3640 guests.
