NEW OTA upgrade for cube talk 9x
    Finally for our beloved cube talk 9x is arrived one of the first OTA upgrade!
    This is a screenshot:
    This is dated January 14th 2015. It is still part of version ROM 2.0
    To perform update is mandatory to have stock recovery installed!
    ENJOY!
    Not sure what you wanna say, ota update was already in 1.8
    How do i get stock recovery installed again, is there a twrp version or must i flash it via flashtool
    Do you know what changed
      No, this is now called FOTA: upgrades are now downloaded and installed automatically!
        Hi
        What's new with this update ?
        Do I need to flash the stock recovery over the TWRP one ?
          changelog is unknown!
          So far I couldn't install this update just because I have only 15% of battery left now, so I need to recharge before upgrade.
          Yes you can easily flash stock recovery over TWRP, perform upgrade and flash again TWRP!
            That's what i did on 1.8
              Update system says to me that i already have the last version. No fota update available for me
              But on mother's tablet ordered at same time than mine i have this update available. I don't understand
                Cannot update. New version found, but release note is empty! And after downloading, nothing happens after hitting update now button.
                  If i use english system update online update, checking during few seconds, and message appears "system up to date"
                  But if I use French language, I have other message "no network"
                    My cube discovered the update but I prefer to download it when I see the change log... Any news on that yet?
                    @giouncino please edit 1st post and add the update date to thread's title. Thank you.
                    Sent from my Cube U65GT, using Tapatalk
                      LatinIME.apk
                      I can't install this update. Every time I get this error:
                      system/app/LatinIME.apk has unexpect contents
                      Update.zip is not correct
                      My system language is finnish (suomi). I have also tried with english (United Kingdom) and chinese. I have also tried to delete all the files that contains finnish letters (å, ä, ö), Nothing seems to work. I have stock V2.0 (20141111) and stock recovery. Not rooted. I have also disabled all the chinese apps but I tried to enable them again but still no luck with update.
                        on mine error is:
                        system/app/calendar.apk has unexpect contents
                        I'll try to understand what's happening soon...
                        be patient!
                          I tried recovery stock, de root, change language (english, chinese, italiano): no succes
                          16go version, build year 2015, week 02
                            I have the 16gb wite version with stock rom and 2.0 firmware installed. Greek UI language.
                            The update downloads and when start the installation, after restart, returns just an "error". This happen when installation process bar reach the 1/3 or so. Seems like the download is corrupted.
                            Several times try with exact same results.
                            edit: The chinese in the update writes
                            Originally posted by Google translate used
                            The version number: 0502L012_EP79-U65GTB18MXXTDC_V2.0_20150114
                            Version Size: 3.04MB
                            Release Date: 2015-01-14
                            The updates are as follows:
                            1. Upgrade version
                            Installation Tips: Select installation, after the phone reboot into upgrade mode. The whole process takes a few minutes to make sure you have enough power.
                              I saw the update install it, but till now I do not see anything new or better.
                              Edit 1
                              The stock recovery police font is bigger so it s more readable.
