I got the "Update.zip is not correct" error. I guess my mistake was that I tried to update a ROOTED Cube. Am I right? Anyway, now my Cube Talk 9X keeps restarting and is looping with it saying "no command" and the Android with an exclamation point sign coming out (see the pic). So my Cube is a brick. Whew.
Do I need a stock recovery FILE (set) which I could copy to my SD card and then use the boot mode to recover ("apply update from sdcard2")? Or? Which file(s), where do I get them? The 14 January 2015 is an OTA, so it does not help me with a half-dead Cube. ;-) Or am I seriously missing something?
The boot mode option "Wipe data/factory reset" does not help. It wipes and formats, but I still get the "no command" loop. The Cube does not boot.
My ROM version is (or was before I attempted this OTA update) V2.0, Tue 11 November 2014. Can I find it as a file set somewhere and would it do the trick if saved on the SD card?
If I had to use a flash tool, how can I do it when the Cube does not boot? The small in white menu (power + volume up)?
What shall I do? Can you please kindly help me? How do I recover? I want my Cute Cube back. Thank you EVER so much.
