Release notes
Hello guys, I guess most of you have noticed that, right now, I'm just working on WeTek products (and couldn't be anything different since I really like doing this kind of stuff for them).
To prove you that WeTek Electronics cares about community and since we don't have any AMLogic S805 product, we decided to make users of MK808B-Plus happy by releasing a CyanogenMOD 11 build for them.
Most of the things I have tried work very good but. probably, few minor things might not be as stable as the stock ROM, in case report it and I will try to fix it.
First install instructions
* As really first thing I suggest you to flash stock "109k4" rom using "AMLogic Burning Tools" in case you're not already using that ROM or Finless' 1.1.
* Grab CWM from here, unzip it and copy "recovery.img" file to a MicroSD.
* Power off your device and unplug the AC power cord.
* Get the latest available ROM and GAPPS version from the links below and copy them to a MicroSD card.
* Now insert the MicroSD card in your HDMI stick.
* Plug the AC power cord while you keep pressed the little reset pinhole (located on the top left of the device) until you see the "Google TV" logo.
* Once the device has booted to recovery perform a factory reset and flash the ROM's zip for first followed by the GAPPS zip.
* Reboot and enjoy CyanogenMOD.
Update instructions
* Enable "Developer options" following this tutorial and from it enable the "Reboot to recovery" option.
* Bring up power menu by keeping F5 (if you have a keyboard plugged in) and select "Reboot -> recovery", otherwise use the pinhole method adove.
* Once the device has booted to recovery flash the ROM's zip for first followed by the GAPPS zip.
* Reboot and enjoy your updated CyanogenMOD.
Downloads
* ROM 2015-01-20
* GAPPS 2014-06-06 (LITE)
* GAPPS 2014-16-06 (FULL, from goo.im)
