[ROM][4.4.4] Unofficial CyanogenMOD 11 for MK808B-Plus - WeTek Gift
WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Is the source available so we can make our own custom builds?
Originally posted by noderat View PostIs the source available so we can make our own custom builds?
Nope, amlogic sdk is under NDA.WeTek Play
CEC is kernel dependant.
@sneak
try to flash againWeTek Play
Originally posted by sneak78 View PostAlso I can't get root access to kodi, it doesn't ask, the screen goes black and I get multiple "root access denied" pop ups.). Kodi will work anyway though since I already use the correct permissions.
If it bothers you flash SuperSU zip.
Originally posted by dmarkey View PostOk, so the supplied kernel doesn't have it then?WeTek Play
Originally posted by ChristianTroy View Postit's normal, it's Koush's Superuser that doesn't work with Kodi's superuser implementation (just search "root access denied" in kodi forum). Kodi will work anyway though since I already use the correct permissions.
I mean if it doesn't work on stock it won't work here as well. To set up CEC on Amlogic you just have to echo some commands to the kernel using some sysfs entries
it's the same as triggering CEC from MboxSettings app (from advanced section)WeTek Play
* ROM 2015-01-19
Upgraded a lot of code, and support for hd audio has been included. Can you confirm me that on stock MX Player can't decode HD audio as well? But works fine if you set the device to HDMI passthrough, in case you don't have an external receiver use the ARMv7 NEON libffmpeg for MX PlayerWeTek Play
There are currently 1575 users online. 0 members and 1575 guests.
