how can I change this to get it installed?
[ROM][4.4.4] Unofficial CyanogenMOD 11 for MK808B-Plus - WeTek Gift
Yes, they are supported since today's build that I'm using a kernel that I've built from sources and I've included the most used gamepads and two well know usb2serial drivers, in case anybody might need them
Code:CONFIG_HID_GENERIC=y CONFIG_HID_PANTHERLORD=y CONFIG_HID_SONY=y CONFIG_HID_GREENASIA=y CONFIG_JOYSTICK_XPAD=y CONFIG_USB_SERIAL_CP210X=y CONFIG_USB_SERIAL_FTDI_SIO=y
@reiver
you have to use the CWM recovery linked in the install instructions in the OP.WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Hi all.
First of all thanks CT for this ROM (yet using your CM11 in my old Aurora2 and giving me a great service), some Q's:
1- Does it work TVBOX launcer and configurations within? (Miracast, CEC, android TV server, Amlogic control server etc)
2- Would be possible to include some dvb drivers to use TVheadend ARM android version?
What is the tv box launcher?
@vn800art, this is not going to happen or I have to supply all the possible dvb kernel modules.WeTek Play
I have no idea, I never used CEC in my life.WeTek Play
TVBOX launcher AFAIK is the default launcher for amlogic based boxes, this launcher links to the special settings app for setting the features that I listed before. Summarizing I'd like to know if with your ROM is possible to set the same settings as the default ROM (let say 109k4) Miracast, CEC, remote servers etc.
Thanks again
Well, I'll be frank, that launcher is butt ugly (and so it is MboxSettings app, in my WeTek Lollipop builds I've integrated the stuff in Android Settings so eyes won't bleed anymore).
If you need all this stuff I suggest you to keep installed a stock based romWeTek Play
There are currently 4112 users online. 1 members and 4111 guests.
