[ROM][4.4.4] Unofficial CyanogenMOD 11 for MK808B-Plus - WeTek Gift
Yes I know the main purpose of CEC but that audio thing... it refers about the eventual audio/sub source? It sounds pretty useless, considering I might want the UI in italian but original audio (say english) and italian subs
It's known that Amlogic CEC works only with certain brands, it's not Amlogic's fault because every manufacturer try to impose its standard.WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Originally posted by ChristianTroy View PostYes I know the main purpose of CEC but that audio thing... it refers about the eventual audio/sub source? It sounds pretty useless, considering I might want the UI in italian but original audio (say english) and italian subs
Originally posted by ChristianTroy View PostIt's known that Amlogic CEC works only with certain brands, it's not Amlogic's fault because every manufacturer try to impose its standard.
That's because it uses libcec that does the nasty work (aka casting the commands to what the manufacturer's cec expects), amlogic has not libcec support, yet.
Anyway in an ideal world a standard wouldn't need all this bullshitvendors should just follow existing standards
WeTek Play
Even from the same manufacturer?
Anyway the thing that every vendor calls it in a different way says already enough... It's a damn CEC why everyone has to put his name on it?WeTek Play
It will work with every device that can be flashed (and are, of course, working) with a stock mk808b+ rom.WeTek Play
Originally posted by k-Rize View PostDoes this rom work on the regular mk808 non BT?
Also, is anyone working on a cm12 build?
But to give you a short answer: NO, it will definately not work. Neither on the MK808B, nor on the MK808.
cifs support is built into the kernel so you can mount it as root, I'm not familiar with cifsmanager but it should work, just be sure to use a writable mount point, you can for example let it mount under "/sdcard/cifs" since "/storage" is read onlyWeTek Play
I don't know about USB sound cards (in Lollipop Android should have a better support for it) but ethernet has the Amlogic implementation (to set a static IP), while in Lollipop I use Android's ethernet service (and you can set a static ip address as well).
Usb ethernet works with supported nics
Code:CONFIG_USB_NET_AX8817X=y CONFIG_USB_NET_AX88179_178A=y CONFIG_USB_NET_CDCETHER=y CONFIG_USB_NET_CDC_NCM=y CONFIG_USB_NET_DM9601=y CONFIG_USB_NET_NET1080=y CONFIG_USB_NET_CDC_SUBSET=y
WeTek Play
There are currently 3274 users online. 2 members and 3272 guests.
