Got to get a couple hours sleep.
[ROM][5.0.2] Unofficial CyanogenMOD 12 for MK808B-Plus - WeTek Gift
Originally posted by ChristianTroy View Post
Got to get a couple hours sleep.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
this
Try netflix, if it fails grab a logcat and save it. Try to flash this zip and see if it works, in case it fails again grab a new logcat and post both of them.WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
(y)
keep me postedWeTek Play
Netflix
Daughter is sick so working from home today....good news netflix works just zoomed out. Do you still need the log? I tester Crackle SPMC Google Movies and TV. It doesn't seem to have broke anything. Google play movies is wierd. This was before as well. If i download the content it will play but it wont stream.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Google play movies is one of the apps that requires Widevine DRM (in fact I noticed the broken DRM because of it force closing with the DRM libraries, without them it doesn't play nothing).
BTW, try to flash again the yesterday's rom (to restore the previous environment) and try this zip instead.
PS: I wish your daughter good luckWeTek Play
Kernel
Is there any way you can make an alternate kernel. One that is not so aggressive to under clock. I understand for most the standard works well. Mine barely gets warm. I would like to push mine and put a fan on it to keep it cool?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
? This is running at the maximum allowed speed: 1536 mhz, you can't go higher than this.WeTek Play
Originally posted by ChristianTroy View Post? This is running at the maximum allowed speed: 1536 mhz, you can't go higher than this.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I see it running at 1536 most of the time, when the load is required. You can set up the performance governor if you don't want to scale it down, but it's just uselessWeTek Play
Originally posted by ChristianTroy View PostI see it running at 1536 most of the time, when the load is required. You can set up the performance governor if you don't want to scale it down, but it's just useless
And performance doesn't seem to act like performance. On the mk808 it would go full speed all the time.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Netflix 2nd Tru
1st was better. To make sure i did it right. I just wiped system and data and data/media. Flashed cm 12 then gapps then 2nd netflix. Rebooted and set it up. Netflix is full screen but skipping. But now that i think about it... i didnt notice artifacts this time..
All testing was done 720Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
post a logcat, I wanna see if omx is acting better. The first version was using a hack to fool netflix and using the media player apis.WeTek Play
2nd Netflix
Looks Cleaner
Code:01-23 17:42:42.008 D/audio_hw_hdmi(141): out_set_parameters(kvpairs(routing=1024), out_device=0x400)01-23 17:42:42.019 D/audio_hw_hdmi(141): select_output_device(mode=0, out_device=0x400) 01-23 17:42:42.019 D/audio_hw_hdmi(141): start_output_stream(adev->out_device=0x400, adev->mode=0) 01-23 17:42:42.020 I/audio_hw_hdmi(141): hdmi sound card id 0,device id 1 01-23 17:42:42.020 D/audio_hw_hdmi(141): ------------open on board audio------- 01-23 17:42:42.020 I/audio_hw_hdmi(141): channels=2---format=0---period_count4---period_size1024---rate=48000--- 01-23 17:42:45.107 D/audio_hw_hdmi(141): out_standby(0xb2706180) 01-23 17:42:45.108 I/audio_hw_hdmi(141): [do_output_standby 855]Clear LastStream/0xb2706180 01-23 17:42:45.157 W/ResourceType(582): No package identifier when getting value for resource number 0x00000000 01-23 17:42:45.158 W/PackageManager(582): Failure retrieving resources for com.nolanlawson.logcat: Resource ID #0x0 01-23 17:42:45.164 I/ActivityManager(460): START u0 {act=com.android.systemui.recents.SHOW_RECENTS flg=0x10804000 cmp=com.android.systemui/.recents.RecentsActivity (has extras)} from uid 10012 on display 0 01-23 17:42:45.221 W/ResourceType(582): No package identifier when getting value for resource number 0x00000000 01-23 17:42:45.221 W/PackageManager(582): Failure retrieving resources for com.nolanlawson.logcat: Resource ID #0x0 01-23 17:42:45.493 I/Timeline(5149): Timeline: Activity_idle id: android.os.BinderProxy@cb73517 time:2539276 01-23 17:42:45.739 I/Timeline(582): Timeline: Activity_idle id: android.os.BinderProxy@11d4c244 time:2539521 01-23 17:42:45.838 I/Timeline(460): Timeline: Activity_windows_visible id: ActivityRecord{1ee1bf99 u0 com.netflix.mediaclient/.ui.home.HomeActivity t24} time:2539621 01-23 17:42:46.784 E/WifiStateMachine(460): WifiStateMachine CMD_START_SCAN source -2 txSuccessRate=82.08 rxSuccessRate=75.73 targetRoamBSSID=0c:d5:02:9e:fa:59 RSSI=-29 01-23 17:42:46.875 I/Timeline(5149): Timeline: Activity_launch_request id:com.netflix.mediaclient time:2540658 01-23 17:42:46.876 I/ActivityManager(460): START u0 {flg=0x10020000 cmp=com.netflix.mediaclient/.ui.player.PlayerActivity (has extras)} from uid 10063 on display 0 01-23 17:42:46.880 E/AudioTrack(460): AudioTrack::set : Exit 01-23 17:42:46.925 I/MediaFocusControl(460): AudioFocus requestAudioFocus() from android.media.AudioManager@65a1b97com.netflix.mediaclient.ui.player.PlayerActivity@15622cb5 01-23 17:42:47.062 D/audio_hw_hdmi(141): out_set_parameters(kvpairs(routing=1024), out_device=0x400) 01-23 17:42:47.073 D/audio_hw_hdmi(141): select_output_device(mode=0, out_device=0x400) 01-23 17:42:47.073 D/audio_hw_hdmi(141): start_output_stream(adev->out_device=0x400, adev->mode=0) 01-23 17:42:47.074 I/audio_hw_hdmi(141): hdmi sound card id 0,device id 1 01-23 17:42:47.074 D/audio_hw_hdmi(141): ------------open on board audio------- 01-23 17:42:47.074 I/audio_hw_hdmi(141): channels=2---format=0---period_count4---period_size1024---rate=48000--- 01-23 17:42:47.205 I/ActivityManager(460): Displayed com.netflix.mediaclient/.ui.player.PlayerActivity: +306ms 01-23 17:42:47.261 I/Timeline(5149): Timeline: Activity_idle id: android.os.BinderProxy@168ff184 time:2541044 01-23 17:42:47.307 D/Volley (5149): [302] BasicNetwork.performRequest: Http status: 200 01-23 17:42:47.585 I/Timeline(460): Timeline: Activity_windows_visible id: ActivityRecord{3aadc7e1 u0 com.netflix.mediaclient/.ui.player.PlayerActivity t24} time:2541367 01-23 17:42:47.587 W/ActivityManager(460): getTasks: caller 10063 does not hold GET_TASKS; limiting output 01-23 17:42:47.852 I/OMXClient(5149): Using client-side OMX mux. 01-23 17:42:47.887 I/omx_core(5149): OMX_Init 66 gInitCount=1 01-23 17:42:47.888 V/AML_all_components(5149): 01-23 17:42:47.888 V/AML_all_components(5149): -------------------------------- 01-23 17:42:47.888 V/AML_all_components(5149): author:aml.sh multi-media team 01-23 17:42:47.888 V/AML_all_components(5149): branch name: 01-23 17:42:47.888 V/AML_all_components(5149): git version: 01-23 17:42:47.888 V/AML_all_components(5149): last changed: 01-23 17:42:47.888 V/AML_all_components(5149): build-time: Wed Aug 13 20:07:59 CST 2014 01-23 17:42:47.888 V/AML_all_components(5149): build-name: brian.zhu 01-23 17:42:47.888 V/AML_all_components(5149): uncommitted-file-num:0 01-23 17:42:47.888 V/AML_all_components(5149): cd /mnt/fileroot/brian.zhu/m8baby 01-23 17:42:47.888 V/AML_all_components(5149): hostname droid05 01-23 17:42:47.888 V/AML_all_components(5149): -------------------------------- 01-23 17:42:47.888 V/OmxComponentManagerImpl(5149): loadLibrary:225 Loading OMX library libOmxVideo.so. 01-23 17:42:47.889 I/omx_core(5149): Core library has 20 components 01-23 17:42:47.895 I/ACodec (5149): sampleRate=48000 channels=2 bits=16 01-23 17:42:47.910 I/OMXClient(5149): Using client-side OMX mux. 01-23 17:42:47.912 I/omx_core(5149): OMX_Init 66 gInitCount=2 01-23 17:42:47.916 I/AmSoftDec(5149): get mimetype : video/avc 01-23 17:42:47.917 I/AmFFmpegCodec(5149): CreateCodec for codecMime : video/avc 01-23 17:42:47.922 E/OMXNodeInstance(5149): OMX_GetExtensionIndex OMX.google.android.index.storeMetaDataInBuffers failed 01-23 17:42:47.922 E/ACodec (5149): [OMX.google.h264.decoder] storeMetaDataInBuffers failed w/ err -2147483648 01-23 17:42:47.923 I/ACodec (5149): [OMX.google.h264.decoder] prepareForAdaptivePlayback(720x480) 01-23 17:42:47.923 W/OMXNodeInstance(5149): OMX_GetExtensionIndex OMX.google.android.index.prepareForAdaptivePlayback failed 01-23 17:42:47.923 W/ACodec (5149): [OMX.google.h264.decoder] prepareForAdaptivePlayback failed w/ err -2147483648 01-23 17:42:47.923 I/ACodec (5149): [OMX.google.h264.decoder] DRC Mode: Port Reconfig Mode 01-23 17:42:47.932 I/AmVideoCodec(5149): Number of CPU cores: 4 01-23 17:42:47.932 I/AmVideoCodec(5149): decoder thread num : 4 01-23 17:42:47.944 E/AmSoftDec(5149): [onQueueFilled 354] status:0 01-23 17:42:50.125 E/AudioTrack(5149): AudioTrack::set : Exit 01-23 17:42:50.167 D/audio_hw_hdmi(141): out_standby(0xb2706180) 01-23 17:42:50.167 I/audio_hw_hdmi(141): [do_output_standby 855]Clear LastStream/0xb2706180 01-23 17:42:50.300 D/audio_hw_hdmi(141): out_set_parameters(kvpairs(routing=1024), out_device=0x400) 01-23 17:42:50.311 D/audio_hw_hdmi(141): select_output_device(mode=0, out_device=0x400) 01-23 17:42:50.311 D/audio_hw_hdmi(141): start_output_stream(adev->out_device=0x400, adev->mode=0) 01-23 17:42:50.311 I/audio_hw_hdmi(141): hdmi sound card id 0,device id 1 01-23 17:42:50.311 D/audio_hw_hdmi(141): ------------open on board audio------- 01-23 17:42:50.312 I/audio_hw_hdmi(141): channels=2---format=0---period_count4---period_size1024---rate=48000--- 01-23 17:42:50.347 I/SoftAAC2(5149): limiting to stereo output 01-23 17:42:50.347 E/AmSoftDec(5149): Cannot decode this frame! 01-23 17:42:50.362 I/SoftAAC2(5149): Reconfiguring decoder: 0->48000 Hz, 0->2 channels 01-23 17:42:50.419 E/AmSoftDec(5149): Cannot decode this frame! 01-23 17:42:50.433 E/AmSoftDec(5149): Cannot decode this frame! 01-23 17:42:50.451 E/AmSoftDec(5149): Cannot decode this frame! 01-23 17:42:50.732 W/AudioService(460): stream was not muted by this client 01-23 17:42:50.732 E/AudioService(460): Could not get client death handler for stream: 3 01-23 17:42:50.734 W/AudioService(460): stream was not muted by this client 01-23 17:42:50.734 E/AudioService(460): Could not get client death handler for stream: 3 01-23 17:42:56.973 W/ResourceType(582): No package identifier when getting value for resource number 0x00000000 01-23 17:42:56.973 W/PackageManager(582): Failure retrieving resources for com.netflix.mediaclient: Resource ID #0x0 01-23 17:42:57.006 I/ActivityManager(460): START u0 {act=com.android.systemui.recents.SHOW_RECENTS flg=0x10804000 cmp=com.android.systemui/.recents.RecentsActivity (has extras)} from uid 10012 on display 0 01-23 17:42:57.014 W/SurfaceFlinger(134): FB is protected: PERMISSION_DENIED 01-23 17:42:57.016 W/WindowManager(460): Screenshot failure taking screenshot for (1280x720) to layer 21055 01-23 17:42:57.016 E/ActivityManager(460): Invalid thumbnail dimensions: 420x420 01-23 17:42:57.078 W/ActivityManager(460): getTasks: caller 10063 does not hold GET_TASKS; limiting output 01-23 17:42:57.080 I/MediaFocusControl(460): AudioFocus abandonAudioFocus() from android.media.AudioManager@65a1b97com.netflix.mediaclient.ui.player.PlayerActivity@15622cb5 01-23 17:42:57.113 W/ResourceType(582): No package identifier when getting value for resource number 0x00000000 01-23 17:42:57.113 W/PackageManager(582): Failure retrieving resources for com.netflix.mediaclient: Resource ID #0x0 01-23 17:42:57.166 I/omx_core(5149): OMX_Deinit 96 gInitCount=1 01-23 17:42:57.426 W/AudioService(460): stream was not muted by this client 01-23 17:42:57.426 E/AudioService(460): Could not get client death handler for stream: 3 01-23 17:42:57.643 V/PhoneStatusBar(582): setLightsOn(true) 01-23 17:42:57.755 I/Timeline(582): Timeline: Activity_idle id: android.os.BinderProxy@11d4c244 time:2551538 01-23 17:42:57.883 I/AudioFlinger(141): BUFFER TIMEOUT: remove(4097) from active list on thread 0xb1501000 01-23 17:42:58.108 I/Timeline(5050): Timeline: Activity_idle id: android.os.BinderProxy@2903d2f1 time:2551891 01-23 17:42:58.154 V/PhoneStatusBar(582): setLightsOn(true) 01-23 17:42:58.473 I/Timeline(460): Timeline: Activity_windows_visible id: ActivityRecord{18327646 u0 com.nolanlawson.logcat/.LogcatActivity t26} time:2552255
Their OMX libraries seem completely broken in Lollipop... just for knowing what you were meaning, can you grab me a picture of your screen while running netflix with the first zip I supplied (no need to reflash or factory reset), to understand what do you mean with the video issue you mentionedWeTek Play
There are currently 2054 users online. 4 members and 2050 guests.
