BTW: I tried Ethernet and it works just out of the box (with a random cheap chinese ethernet adapter).
[ROM][5.0.2] Unofficial CyanogenMOD 12 for MK808B-Plus - WeTek Gift
You can't, at the time I released this rom I had not included the remote control app. I've kept updating only the WeTek Play rom (which has it working).
Regarding miracast it's not going to work. OMX is required. It will on 4.4 I guess, never been interestead in it, it's laggy as hell with a tremendous latency. Cable FTW.WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
You can try to replace superuser with supersu and see if anything changes. Kodi startup takes always some time, even on my htpc with a Phenom II X4 and a Samsung 840 EVO.WeTek Play
How can I change the Superuser with SuperSu? Do I just install SuperSu and assign the rights?
Laggy, that is in all applications, when I click the mouse and see it on TV, need 0.5-2 seconds to start this action
Edit: I installed SuperSu, I do not see less lagg...Last edited by darko150; 20 February 2015, 17:02.
Oh, the initial boot? I thought you were referring to the fact that Kodi takes some time to start.
Well you have to think that the S805 is an underpowered SOC (even if it behaves pretty good for its price) and Android loads tons of stuff at boot, you have to let it settle. Think of it like a 10 years old Win XP pc.
Guys really, the marketing could advertise them as "mini-pc" but the fact is that they are not even close to a 5 year old celeron.
BTW the more apps you install the more chance that the app does something at boot exist, on CM you can disable these things using AppOps.WeTek Play
Originally posted by ChristianTroy View PostOh, the initial boot? I thought you were referring to the fact that Kodi takes some time to start.
What's the answer? You have to let it settle it's not an i7 with a fast ssd. If you're prompted with the launcher it doesn't mean boot has ended. Once it has settled and all boot services or app have started it's as fast as oe (almost since oe is not poisoned by java). If oe fits you better just use it. I'm not jealous :PWeTek Play
Originally posted by ChristianTroy View PostWhat's the answer? You have to let it settle it's not an i7 with a fast ssd. If you're prompted with the launcher it doesn't mean boot has ended. Once it has settled and all boot services or app have started it's as fast as oe (almost since oe is not poisoned by java). If oe fits you better just use it. I'm not jealous :P
People asks for Android and manufacturers give Android. Market share of Android is > 80% so they don't care if it's laggy as long as it has apps.WeTek Play
Originally posted by ChristianTroy View PostPeople asks for Android and manufacturers give Android. Market share of Android is > 80% so they don't care if it's laggy as long as it has apps.
There are currently 2118 users online. 0 members and 2118 guests.
