Thanks by your work
[ROM][5.0.2] Unofficial CyanogenMOD 12 for MK808B-Plus - WeTek Gift
Yes and there's no cec problems with both my TV.WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Have an issue regarding videos played in Kodi 14.2.
Some (480p .avi's). play in only in a portion of the upper-left of the screen when the stick's resolution is set to 1080P , but will play ok when the stick is set to 720p.
Kodi seems unstable and quits at the 720P res...
Checked settings/system/video output/video calibration when at 1080p and it looks mucked-up as well:
any clues on how to fix?
P.S. issue goes away when system/video/acceleration/decoding method is set to Software , seems like the videos freeze when set on Hardware acceleration with only one or two of the HW methods set.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by dy57; 15 May 2015, 06:11.
You're supposed to use 15.xWeTek Play
Just turning on CEC from display settings. My TVs are a Sony KDL50W829B and a Panasonic TX-40AS640eWeTek Play
CEC will be the same on both as OE uses mostly codesnake's work an the included kernel has the same CEC patch as OE's.WeTek Play
Have you thought to do cyanogenmod 12.1 for wetek play and mk808b plus? I say it because it seems that now cyanogen adds the interface of androidTV and for the improvements that there are from 5.0 to 5.1.
I say it for the build that they did for the nexus player: http://forum.xda-developers.com/nexu...-fugu-t3086597
Originally posted by mega-samu View PostHave you thought to do cyanogenmod 12.1 for wetek play and mk808b plus? I say it because it seems that now cyanogen adds the interface of androidTV and for the improvements that there are from 5.0 to 5.1.
[ATTACH=CONFIG]n503702[/ATTACH]
+1
The mk808b plus is shipping with a new wifi chipset, the AP6212, kszaq has managed to get the source code for it which is working correctly for Openelec, could you please add it to the next version of CM.
Thanks.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
That would be great!!
Follow the following instructions to use Leanback Launcher
- Download the Leanback launcher APK on your MK808b plus
- Install Zipsigner on your MK808b plus https://play.google.com/store/apps/d...ood.zipsigner2
- Start Zipsigner on MK808b and sign LeanbackMod.apk with key 'playform'
- Create a new folder on your MK808b with Rootexplorer (system/app/LeanbackMod)
- Place the LeanbackMod-signed.apk in that folder.
- Restart your MK808b and Leanback launcher is available to use.
There are currently 2049 users online. 0 members and 2049 guests.
