NEXT7D12F
How's the ROM working out.900Supersport
freaktab developer
Originally posted by 900supersport View PostHow's the ROM working out.
The spontaneous reboot was due to the SD card. I ran it with no card in for a couple days, and had no trouble at all. I put in an 8G card, FAT32, and it ran fine. I then put in the 32G NTFS, and it started acting up again. I did a FULL format on the 32G NTFS, and haven't had a problem. I chalk it up to a poorly formatted (quick format) of the 32G of NTFS.
So, the bottom line is this: If you have a NEXT 7D12F, and want an awesome ROM on a great spec'd and inexpensive tab, download this ROM, do a full format on your SD card and then have fun.
Great job Supersport!!!
Here's the link to the ROM kit
http://www.freaktab.com/showthread.p...ll=1#post38621
This should see you sorted. Happy to help if you have any issues. JW ended up changing to stock recovery rather than CWM as this sorted out a few issues with files systems. I'd advise trying CWM, and once you are flashed check memory etc, if your a long way short of the 8 gig (soem always taken up by the ROM and some reserved for apps) then try the stock recovery.900Supersport
freaktab developer
Re: NEXT7D12F
You beat me to posting the link Supersport!
The link to the download is the final version with Clockwork Recovery Mod. I flashed this succesfully, but ran into trouble with my external sdcard and had to flash another time with the stock recovery. I've been running that ever since. I'd flash with no card at first.
As for getting into flash mode and such, I posted my steps on roughly page 2 of this thread. I'd post a direct link but I'm still getting used to this tapatalk app!
Pretty easy flash as Supersport cooked up a great ROM for us! We have full use of all hardware of the tab, rooted with google play.
Let me know if you need help.
Sent from my EBM727KC using Tapatalk 2
See post 33 for entering flash mode900Supersport
freaktab developer
Originally posted by redneck View PostOk flash went well. Now i am getting the Damaged Storage icon. I click on it and it says: "Unfortunately, System UI stopped. Where did i foul up at?
Re: NEXT7D12F
I'll update the Rom kit so it comes like this. Thanks for the feedback.900Supersport
freaktab developer
Originally posted by redneck View PostI had to rename the recovery.img to recovery.old and then renamed the recovery.img.orig to recovery.img. I reflashed and the problem went away. So far so good.
Have you had any issues running an external SD card?
Thanks Supersport for updating the ROM kit for others. I wish I knew more about the magic you wield to help you!
Re: NEXT7D12F
Hey this one is easy, rename a few files zip and upload.
If you want to learn about cooking roms we have some good threads on freaktab.900Supersport
freaktab developer
Originally posted by jwjensen View PostYep, same thing happened with me. Running with original recovery.img seems to be the best for now, confirmed by your flash.
Originally posted by redneck View PostFor some strnge reason my win 7 box would not formt my 32 gb sd to ntfs,so I formatted fat32. It seems to be doing ok. Love this little tablet. Would highly recommend to anyone looking for a cheaper tab with bt. Thanks a million to Supersport for his continuing efforts. Thanks to you JW for the testing.
Yes, I love this tab, too. It was cheap, and it has great memory, speed, and bluetooth! Highly recommended, WITH this ROM of course!! Thanks again Supersport!
900Supersport
freaktab developer
There are currently 3918 users online. 1 members and 3917 guests.
