Hardware Device Compatability List
    MK808 CYANOGENMOD 10 - Goobay 315038 Net WLAN USB 300Mbps
    This Dongle ran out of the Box, great performance for me (connects 300MBit @ 80% Signalstenght). Router says connected with 300MBit - Data Rate 270MBit/sec
    here is how i did it http://www.armtvtech.com/armtvtechfo...8e9e9cd606da38
      vista mce remote
      didnt think it would work but it does. its a remote control for windows media center ect. just decieded to plug it in and see what happiened
      mouse pad buttons work great the volume play pause stop close buttons work great.
      music button opens apps settings for some reason
      the arrow keys move from app to app which is cool
      clear button closes app
      the power/sleep button turns off the screen picture. (turns off hdmi signal) when you press power button again mk808 wakes backup in the lock screen (hold click and drag to unlock)
      device is a mk808 not sure which rom is running it came rooted the menu bar hides in some apps no wifi problems the kernerl says premptoct11
      [image]http://bestoffershop.com/products/gigacity/img/4094/4094_04.jpg[/image]
      more info here cant find an actual site for it http://www.****.com/itm/Wireless-PC-...item43b5dfa67a
      this $5.00 mouse also works great the green one http://www.****.com/itm/251016389944...84.m1497.l2649
      also got a 250 gb external hardrive i made on it from a laptop baught a cheap 7.00 case from **** to convert it to usb power for harddrive is pluged into the tv( to unplug power to mk808 power and external hard drive have to be unpluged or i still get power)
        Originally posted by jased10s View Post
        UG802III custom jellybean 4.1
        Working and all shortcut buttons working
        Perixx PERIPAD-701, Wireless Touchpad With Backlight Keyboard
        does multitouch work?
        how many points were detected?
          this nice cheap generic webcam does not work on my mk808 running which ever rom came preinstalled ether that or i dont know what app to use
          http://www.****.com/itm/USB-16-0M-Me...item1e62491fc7.
          Well found out it works some what with icscamera crashes after a few minutes saves pictures also works in livefx but screen isent live
            UG802 with Finless ROM v1.6
            Logitech QuickCam Pro 4000 doesn't work.
            Microphone is detectable, but isn't compatible with Google Voice Search and Skype. The video part is totally unusable.
              AW: Hardware Device Compatability List
              Mk808 with Finless 1.5a
              logitech k400 keyboardwith touchpad own dongle
              Logitech m305 cordless mouse with own dongle
              Belkin external powered 7 port usb hub
              Logitech pro 9000 webcam, is detected, mic is very noise in voicemessage test and googlesearch crashed
              mad catz 2.4 ghz usb ps3 gamepad , right stick notworking, rest is good, could play tekken 3 on fpse with it
              tv is a samsung ue46c7090 and a samsung c-500 amp. Stick is working on acer hl241 monitor too... 22" lg monitor has problems with stripes and black screen
              Gesendet von meinem GT-P7500 mit Tapatalk 2
                Rikomagic MK802 III
                Rikomagic MK802 III
                Android 4.1.1
                Kernel 3.0.8+
                Build 20121031 (=original firmware)
                (powered) USB HiSpeed Mini Hub from Konig -> ok
                Logitech Unifying Mouse M705 + Keyboard K520 -> ok
                Sound options:
                1. HDMI -> Acer Monitor P244W Monitor audio out -> MP3 earset -> ok
                2. USB sounddevice (speakers came along above monitor) -> ok
                3. Headset + mic “Platronics C420-M” -> ok
                Logitech webcam pro 9000 “works” with apps “fxcamera” but “freezes”taking a picture,
                and those pictures cannot be found. With skype simular problems.
                In other words need a different cam;-).
                  hello,
                  1.I'm running rom finlass rom 1.6 stock, on ug802 .
                  2.A.Xbox 360 cable, work flowless! (GTA 3).
                  B.Web cam, Microsoft LifeCam VX-2000, perfect audio and video for skype use!
                  C.Wirless keyboard and muse ,Logitech K220 ,also work flowless with all keyboard shurtcuts.
                  D.Hard disc ,1TB hp 1000h ,work great with full hd movies plus good idle mod when not in use .
                  3. all work with stock settings.
                  p.s.
                  Bob great work !
                    DroidMote works...makes your SmartPhone work like touchpad
                    Running finless rom 1.6 on ug802
                    DroidMote works; On my Samung Galaxy I have DroidMote Client and on the UG802 I have the DroidMote Server. Now I use my Samsung smartphone as touch pad (even multi finger).
                    The DroidMote Client is free but you have to buy the DroidMote Server via PlayStore on your Smartphone...mail this app without opening to yourself and install it direct on the UG802
                      MK808
                      MK808
                      Finless 1.5a ROM
                      Working
                      MTK 2.4ghz Wireless keyboard and mouse
                      Microsoft HD-5000 webcam - both sound and video working well in Skype
                      all connected through Belkin H-7 powered hub
                      Not working
                      Microsoft VX-1000 webcam - no picture or sound
                      cheers
                      mutton
                        MK808
                        MK808
                        Finless 1.5a ROM
                        Working
                        RC11 2.4ghz Wireless keyboard and mouse
                        Logitech C310 HDwebcam - both sound and video working well in Skype
                        Not working
                        Bluetooth Class I billionton
                        Usb WiFi RT73
                        EnderA
                          UG802
                          I have UG802 updated with Finless 1.6 ROM:
                          working:
                          - Logitech webcam C210 (out of the box, audio and video)
                          - iPazzport USB Rechargeable Handheld 2.4G Wireless Qwerty Keyboard w/ Touchpad & Laser Pointer
                          - and (so far), everything connected to 7-ports Powered USB HUB
                            working:
                            - Microsoft Lifecam VX-5000 (out of the box, audio and video)
                            - logitech MX5000 combo mouse kboard
                            - logitech dualaction gamepad
                            - and (so far), everything connected to 4-port Powered USB HUB
                            Cordless Desktop MX 5000 Laser
                            Model Number:
                            Y-RAH72 (Keyboard)
                            M-RBA97 (Mouse)
                            Your Cordless Desktop MX 5000 Laser uses the Logitech USB mini-receiver P/N 830-000002 (this is compatible with earlier receiver versions P/N 831406-1000 or P/N 831406-3000).
                              WebCam
                              Finless 1.6 ug802, Logitech Webcam C210 work
                                MK802 II
                                FW HBD400
                                Working
                                MSI Powered USB hub 7
                                Web cam Gembird CAM90U Both video and audio
                                Logitech Di novo edge
                                Logitech HD Pro C910 only video works in any app mic no again
                                By the way great thread
