this psp charger easily moddified works well as a 5v 2a power source
Hardware Device Compatability List
@white-enochian
This topic have name Hardware Device Compatability List and that does not mean RK3066 compatibility list.
MK808 w/ Finless 1.5A
USB Ethernet adapter from Monoprice.com (PID 6150) works. This is an ASIX AX88772A chip (idVendor=0b95, idProduct=772A).
Also using a mouse, keyboard, and 7port powered USB hub from monoprice, all work.
Neat trick with the USB hub: The hub's upstream port is connected to the MK808's A port and another cable from one of the hub's A ports is connected to the MK808's Mini-B power port.
MK808 w/Finless 1.5a
I am running Finless 1.5a on my MK808 and SS808 (same device with different name as far as I can tell). All of the following devices work with both.
Belkin USB to ethernet adapter model: F4U047-RS
bought from Radio Shack: http://www.radioshack.com/product/in...uctId=12182056
Gigaware 4 port powered USB hub model:2600160
bought from Radio Shack: http://www.radioshack.com/product/in...ductId=2476717
Plugable 7 port powered USB hub model: USB2-HUB-AG7
bought from Amazon: http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
iPazzPort 2.4GHz Mini Wireless Fly Mouse Keyboard with Remote
bought from Amazon: http://www.amazon.com/iPazzPort-2-4G.../ref=de_a_smtd
Logitech K400 wireless keyboard with touchpad
bought from Amazon: http://www.amazon.com/gp/product/B00...ls_o04_s00_i00Last edited by Horrorzilla; 04 December 2012, 16:56.
Apologies if this is not the right thread to post this (any advise appreciated). Is there someone here who has managed to run a 3g USB dongle on their MK808. I have not found much luck yet and been trying with a Huawei EC 150 to connect to a mobile broadband internet. MK808 doesnt even detect it as a modem but just as a storage device. The only other option I can find is to buy a 3g router but....
Imito MX1
Working
Rii Mini Bluetooth keyboard from http://www.amazon.fr/dp/B008JBTL7A/r...430471_3p_dp_1
External 2.5" 500GB HDD / NTFS. Read OK
Write KO
Write KO
Sound card and Network
Original and all of Finless Rom UG802, MK802 compatible! Do not connect the USB OTG! König 3d sound USB sound card, network card and USB JP1082 works very well. The choice between sound card and webcamera(Logitech C170) settings menu does not work at the same time!
USB JP1082 LAN
Logitech C170Last edited by Sigismundpower; 18 December 2012, 12:54.
There are currently 4802 users online. 1 members and 4801 guests.
