Hardware Device Compatability List
Originally posted by Haris1977 View PostIt says that Supports 12Mbps high speed transmission mode, but in fact people say that speed is limited to 6 mbit..Besides the speed limitation, does it work?
Aside from the speed issue it is plug and play, very simple, turn of your wifi first, plug in (may need a reboot with it plugged in), turn on ethernet and away you go.
But with my wifi OK it offers no advantage over the 54mbps I am getting over the air
Logitech K700 Keyboard
Works great. Even has back and home key on it.
Note: You must hook up to your PC first and download Logitech software to pair the keyboard with the unifying receiver. Then move receiver to your MK802III and surf away.
EDIT: Even though it is in my sig, I am have an MK802III running 2dark4u/Finless v1.7 1080p/1272HZ.MK802III Runnin' the Fin v1.7
Mk808 with Finless 1.6
The following hardware does work with the MK808
* Fly Air Gyro Sensing Mouse Wireless Keyboard (http://www.amazon.co.uk/2-4GHz-Sensi.../dp/B008S73V8A)
The following hardware do NOT work with the MK808
* Edimax EU-4230 USB 2.0 to 10/100Mbps Adapter (http://www.amazon.co.uk/Edimax-EU-42.../dp/B0029VJK5E)
MK808
Originally posted by cernymuz View PostMX1with finless 1.4
goigame PS3 controller works
http://dx.com/p/goigame-rechargeable...ite-red-112272
Has anyone Tested These controllers with MK808 Finless 1.6 Rom?
MK808B with FinlessROM 1.5 Level One USB-0200
This is an Gigabit USB-LAN Adapter i found in the box of unused parts.
Works great even so my other Network components are only 100 MBit.
frog2001MK808B (Original with BT, not the clone)
Finless 1.7 beta (still testing)
9 voices in my head are saying: "You are not mad"
The tenth whistles the melody of Tetris
Originally posted by Horrorzilla View PostMK808 w/Finless 1.5a
I am running Finless 1.5a on my MK808 and SS808 (same device with different name as far as I can tell). All of the following devices work with both.
Belkin USB to ethernet adapter model: F4U047-RS
bought from Radio Shack: http://www.radioshack.com/product/in...uctId=12182056
Gigaware 4 port powered USB hub model:2600160
bought from Radio Shack: http://www.radioshack.com/product/in...ductId=2476717
Plugable 7 port powered USB hub model: USB2-HUB-AG7
bought from Amazon: http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
iPazzPort 2.4GHz Mini Wireless Fly Mouse Keyboard with Remote
bought from Amazon: http://www.amazon.com/iPazzPort-2-4G.../ref=de_a_smtd
Logitech K400 wireless keyboard with touchpad
bought from Amazon: http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
There are currently 2244 users online. 1 members and 2243 guests.
