Arnova 9 G2 Custom ROM by Finless V1.3 available!
Also check the loader box as you may have such an old loader it may not be able to use the new structure of the ROM.
Hmmm OK let me double check my package setup.
Please look in the Image folder of my kit and tell me what version of the Loader is in there? It will be either 2.06 or 2.08. I am at work and cant look at my files right now.
For you guys having flash problems. It maybe the old loader.
In my package is loader 2.06. I did not update it to 2.08. The loader is in the image folder of my ROM kit. On the flash tool of the loader line you can flash 2.06 by clicking the box to the right of the loader line and locating the loader 2.06 file. The when you check the box to the left you will not get a loader not found error.
Here is loader 2.08 for you to try snd see if it helps with the formatting. Unzip this and copy it to the Image directory of my ROM kit. When you check the loader box it should work but if not again on the right of the loader line click that and locate the loader 2.08 file.
Please let me know. If 2.08 solves the issues I will update the ROM kit to include 2.08. I did not include it in rev B of my ROM kit as I was worried when people were having issues with my rev A kit.
seems perfect !!
Everything seems to be perfect !!
I just used Bob's 2.08 loader version and it worked fine, formatting was a success and my tablet seems to run correctly.
Sorry for all my posts, as you could guess, I am not really an expert in these stuff...
And a special thank you to Bob to provide this ROM and to take time to solve my problems while at work !!
Regards.
Ben
OK so loader 2.08 solved the formatting problem?
Please confirm 100%
I will make a rev C of my ROM with loader 2.08 if that is the case.
UPDATE 2/1/2012. I have updated the 9G2 firmware with Loader 2.08. This will solve some of the formatting issues some people had. e.g. on reboot into recovery system formatting data for instance might fail. Loader 2.08 seems to have solve that.
SO IF YOU HAVE A FORMATTING ERROR, please make sure you check the box in the flash tool for the Loader.
Use the download link above and note the new file name is
arnova9g2_v1_3c_market.zip
This is so you know you have the correct one and not the old one.
Go here to get version 1.3c
Download my ROM Kit and flash it. When done you will have a fully rooted Arnova 9 G2.
Excellent Rom, thanks. I posted on the 10G2 forum about my issue with the 'wipe fail' but this is sorted by the latest version.
A thing that would be nice would be to include a kernel to support SetCPU (not sure how easy this would be).
Oh and if the screen could be rotated by a whole 180 degrees - this was an issue with stock too. If you install, for example, spotify, or you disable auto rotate, portrait is upside down.
Well as for CPU control I can look into that but it will probably require modifications to the kernel. This is not something I am good at.
However for screen rotation and orientation, that can be done pretty easy I think as it is set in build.prop. I will look into it at a later date. FYI I have noted this though. What some people consider upside down, others do not
Originally posted by Finless View PostWell as for CPU control I can look into that but it will probably require modifications to the kernel. This is not something I am good at.
Mine is also turned upside down. Caption ARNOVA on the frame is turned upside down and buttons are down right.
But there is something positive in this 'thing', its easier to have a charge coupled below as above when you use it.
BrankoH
There are currently 3322 users online. 2 members and 3320 guests.
