Bob has been cooking last night and I am sure he will be today as well. New things to come.
Arnova 9 G2 Custom ROM by Finless V1.3 available!
Guest
You are welcome, enjoy.
Many thanks. I'm a bit worried I've lost some storage
Originally posted by Finless View PostUPDATE 2/1/2012. I have updated the 9G2 firmware with Loader 2.08. This will solve some of the formatting issues some people had. e.g. on reboot into recovery system formatting data for instance might fail. Loader 2.08 seems to have solve that.
SO IF YOU HAVE A FORMATTING ERROR, please make sure you check the box in the flash tool for the Loader.
Use the download link above and note the new file name is
arnova9g2_v1_3c_market.zip
This is so you know you have the correct one and not the old one.
Go here to get version 1.3c
Have flashed and very happy however i only seem to have 2gb storage rather than the 4gb i expect. Is this a config issue?
This is a uk version. It says 4gb on the box but to be honest i didn't check storage before flashing. any ideas?
Originally posted by pswartout View PostHave flashed and very happy however i only seem to have 2gb storage rather than the 4gb i expect. Is this a config issue?
This is a uk version. It says 4gb on the box but to be honest i didn't check storage before flashing. any ideas?Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
That answers that
Originally posted by Damo View PostAlthough it may be 4GB part of that is taken up by the android operating system etc, you can always expand via sd and keep large files like videos and pictures on there. It does not sound alot that you have but you can install hundreds off apps without running out of space. Any large 3d games just move to your sd card
Well done kingofpain !
Glad to see you got it installedPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Guest
Originally posted by kingofpain View PostNew problem encounters now, I sign in Google Acount with Android Market or other Google Apps, and getting error Can't Establish a reliable data connection to the server .
Please help me again .
Like Will said. Can you browse the internet and is WiFI working? Make sure that is working first before the Market.
Guest
You were right Bob, I was wrong. Go ahead and tell him the real fix.There is a file you have to delete.
OK read the first post for my ROM where I talk about that problem. I will post it here again to make it easy
_________________________
4) Market issues. Market issue "may" still exist. This is common on tablets that are not really supported by Google as a registered device. Most users have no issues but sometimes there can be, The 2 issues that seem to arise when your FIRST TIME try to use the Market are:
A) Cannot logon; "Cannot establish a reliable data connection"
I have tried to recreate this and troubleshoot this. My belief if in fact this happens sometimes when Google servers are doing something or something is going on with them. WHen I had this happen once I simply waited a while and it worked later. So I cannot help too much here. My only suggestion to try is this
a) Install a root file manager like root explorer or ES file manager (enable root access for them)
b) Go in with the file manager and delete /data/misc/imei/ data.dat
Please let me know if this solves it for you.
Just back form my breakfast, Deleting that file with RootExplorer still not fix my problem. Another information (if needed) that I installed ArcTools from Appslib after rooting using this ROM, then I download AndroidMarket v3.4.4 from ArcTools. Am I making this wrong by using it ? Hope not.Looking forward to more solutions.Thanks !
There are currently 3495 users online. 1 members and 3494 guests.
