Sent from my SK17i using Tapatalk
Arnova 9 G2 Custom ROM by Finless V1.3 available!
As for you been stuck do Android 2.3.1 I can't see Arnova upgrading to anything above that as they are a budget tablet company, your only hope is for a Rom developer spending a lot of time converting everything to a newer version of Gingerbread but for all the work it would involve it would not be worth it
Sent from my SK17i using TapatalkPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Stuck in the past then...?
[QUOTE=Damo;5100]As for you been stuck do Android 2.3.1 I can't see Arnova upgrading to anything above that as they are a budget tablet company, your only hope is for a Rom developer spending a lot of time converting everything to a newer version of Gingerbread but for all the work it would involve it would not be worth it
/QUOTE]
so is there no hope for the 9 g2 to go further? I've only just bought one and was duped by pc worlds add which says "OS version - gingerbread , now upgradable to ICS" , i might just take it back and swap it for something that supports a more current OS.....
Ics ideally needs 1gb of ram to run properly but that is not to say it wouldn't run. Try getting Pc world to contact Arnova as to if this is to be upgraded to ics as contacting them yourself , you will get a dumb answer as there customer service for answering questions is lame.
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
hmm....
i already tried arnova, I wrote a nice long message, the answer came 3 days later which was "no you cant"
i might see what options pc world give me, although the tablet is really impressive for the price so I'm reluctant to return it,
is there much benefit to me on the 9 g2 from using a ROM upgrade to get honeycomb?
Forgive the dumb questions, I'm a windows techie so android is uncharted territory, I'm used to dell and HP servers running an over expensive OS!!!
Originally posted by iany View Posti already tried arnova, I wrote a nice long message, the answer came 3 days later which was "no you cant"
I would stick with Bobs Rom on Gingerbread if you decide to keep it, the Rom is fast.
</form>
help!
Originally posted by BrankoH View Post4) Press and hold Menu button
is it esc/home/reset , all 3 ?? usb connected first or after reset?
thanks!!
Ian.
Originally posted by iany View PostI've tried all combinations of all sorts and mine just boots up normally as soon as u release the rest button, what exactly is the process to get into recovery mode on the arnova 9 g2 ?
thanks!!
Ian.
- connect the USB cable
- switch off the tablet
- press Menu + Reset
See my detailed post here:
Filippo
thanks !!!
Originally posted by fillab View Post
Originally posted by steviep View Post1st thing a big thank you to Finless worked 1st time and is working great, I know I've asked before but do you ever think we will see GPS support in your roms for the 9G2 I would love to be able to use mine as a truck satnav one day.
Thank you
Brit
As friend wants either this or new smaller 7d g3 model
sent from my Arnova 10 G2
During daily usage at medium-high brightness you can expect it to last about 5 hours.
At low brightness the screen is really dark. I find it perfect for "couch web surfing" at night when all lights are off. But during the day you can't almost see what's on the screen at this level.
Originally posted by fillab View PostBattery life is medium/low, depending a lot on the screen brightness (which can be set within a really wide range). My guess: between 4 hours at max brightness to more than 10 hours at min brightness.
Recovery Mode Arnova 9 G2
thanks!!
Ian.
1. Connect the USB cable
2. Switch off the tablet
2. Press Menu + Reset
There are currently 2210 users online. 2 members and 2208 guests.
