By request here is a custom ROM for the MK808-B
This is ONLY for the MK808-B (with Bluetooth) and not the regular MK808! If you flash the wrong ROM good chance wifi will not work.
Features in 1.5 ROM:
1) Fully rooted with the latest SU and SuperUser.apk
2) Debloated of china and other junk APPs.
3) Added hide status bar button to the status bar. To return the status bar go into settings etc.
4) Special add for this ROM. Full init.d support! If you do not know what that is... ignore it.
If you do, you can now install and use boot time scripts like V6 SUper Charger!
5) All APPs are up to date as of 12/28/2012! So you will not get any Google Play APPs needing updated.
6) Cleaned up the file system so it is not fragmented! Basicly I used linux tune2fs when making the images.
7) I added a reboot APP that will allow you to reboot the device from the Android UI. No more unplugging the unit!
It will also allow you to reboot to ROM flash mode and later when I add ClockWOrk Mod, it will reboot to recovery.
8) ADDED BONUS User APP space by default is only .5GB. I have increased that to 2Gig.
9) The Xbox XPAD.KO module is now injected on boot. This was by request! Enjoy!
10) CIFS, TUN and MD4 KO modules were also added by request.
__________________________
In the ROM kit there is a read me! This has full instructions for how to upgrade. So PLEASE read the read me!
Here is my Finless 1.5 MK808B ROM:
ROM -> MK808-B Finless 1.5 ROM with init.d (218 megs)
Enjoy,
