NEW - MK808-B mini TV Player - Finless 1.5 Custom ROM
Originally posted by avvweb View PostThat pixel corruption happens only with the HW+ mode. If you switch to HW the pixel corruption goes away. Furthermore, in my case the corruption only happens when streaming from network.
Originally posted by spinx View PostThank you! I will try that. Any input on the CIFS-Manager problem? Does this ROM support it? From what i can see it should.
I'm using it and never had trouble.
By the way, Keep in mind the XBMC-stagefright is a test for a solution. even less than a beta version.
your best solution is XBMC+MxPlayer right now.
The main issue here is that MXPlayer wont launch from XBMC when i try to play something from the FTP-folder that i have added (i had to go with FTP since i cant get CIFS to work, this works fine with my AppleTV). Theres only a popup windows saying somthing like "Press OK when external player has finished". I have seen some ppl claiming that its because of the network share?
Thank you Finless for your awesome work! Keep it up!
Hopefully we can get true 1080p support soon....
Btw, I had problem updating the superuser. It prompt me root access denied but I have no problem with titanium backup and es explorer accessing root. Any idea why is this so?
Beside, where can I find the screen shot icon as it was being replaced by the hide arrows on the navi bar?
All in all this is a great rom with everything working great! Thanks again for your great support on this device and hope to see more updates coming in....
Anyone tried this as a dlna server/client?
https://play.google.com/store/apps/d...y52ZWdhLmFkIl0.
Please share your thoughts
*ps1 this app needs a windows server app too,as all of the dlna players
**ps 2 i tried it in my samsung galaxy s 3 and works almost perfect..i dont have my own mk808B -yet- though to try it. This app suports upnp subs too !!!:PLast edited by Haris1977; 24 January 2013, 16:28.
Originally posted by spinx View PostI think i expressed my problem badly, i dont use the Stagefright-version of XBMC, its the "XBMC Android HD Playback Setup by lewy20041" found here http://www.armtvtech.com/armtvtechfo....php?f=6&t=834
ditch that and go there :
Original or Fake?
Bought mine from DealExtreme and was wondering if the 1.5 ROM would work for my 808B and if it was a Real one or a "Fake" one.
I can see my router wifi under the wifi settings and it says it has a good signal but when I try to connect the wifi bars drop to 1 (it shows full bars before connecting) and then stops trying to connect.
Thanks.
Additional Info from the "About Device" is as followed
Model Number : MK808B
Android Version : 4.1.1
Kernel Version : 3.0.8+ olsen_V_401j1 #25 SMP PREEMPT Sat Nov 24 12:51:50 CST 2012
Build Number : mk808b_400j1_20-11-2012
Edit : Just downloaded "Connectify Hotspot" on my laptop and have been using that to piggy back my wireless connection to the MK808B so I am able to connect to the internet and connect to GooglePlay. So far it has been working great and very fast.Last edited by ions; 26 January 2013, 05:50.
Ions, try not to keep the device exactly behind the tv. See if using an hdmi extender n keepin the device away from the clutter helps. Or have a look at this http://vondroid.com/threads/mk808b-c...onnector.4804/
Sent from windows phone.
Sorry couldnt make hyperlinks
Thanks for this rom , it runs perfectly but i have a major problem , i would like to use ps3 bluetooth wireless controler with it , but no success
i turn on bluetooth but it doesnt find anything
Anyone could help me please , i would like to play games .
thanks a lot
this is my controller http://www.subsonic.fr/en/product/playstation-3/neo-1
Originally posted by rishidoshi View PostIons, try not to keep the device exactly behind the tv. See if using an hdmi extender n keepin the device away from the clutter helps. Or have a look at this http://vondroid.com/threads/mk808b-c...onnector.4804/
MK808B now reboots
Hi, thanks a lot for the ROM, I'm finding it very cool. However, I have a problem with my device, it reboots itself. Sometimes it happens randomly, but specially, when I stress the gadget too much. If I'm playing a high resolution video with MX Player, first, Wifi disconnects, video become choppy and after a few more seconds the system reboots.
I tried setting the CPU freq to 1200 GHz, doesn't make a difference. Also, the app Android System Info reports that the CPU is always running at 1008 GHz, regardless of what I set.
Any suggestions?
Thanks in advance!
Originally posted by freddy_krueger View PostThanks for this rom , it runs perfectly but i have a major problem , i would like to use ps3 bluetooth wireless controler with it , but no success
thanks a lot
Hy Bob,
yesterday i flashed your 1.5 on my MK808b with 903 chip. All works great, i only could not start dice player.
Every time i get "Dice Player -> Video Playback Sorry this video cannot be played"
I tried to clear cahe and data for dice but no chance...
Hope somebody could give me a advice
And after there is a new image from 15.01.2013 from geekbuying...did you have a plan to update your rom? It would be awesome if we can get a update ;-)
best regards and thanks for your great work :-D
Craxx;-)
There are currently 2828 users online. 0 members and 2828 guests.
