NEW - MK808-B mini TV Player - Finless 1.5 Custom ROM
Originally posted by jpart View PostHello,
Just got my 808B and I´m going to try to flash it with the rom in the first post (https://a170132.uranus.1blu.de//data...74.php?lang=en)
There should be readme.txt in the zip file but it´s missing? Should that same zip contain also ROM FLash Tool.exe which is mentioned in the few posts above? Because that´s missing also. The zip package has RKBatchTool.exe which does not find my device at all. Is that the mentioned rom flash tool? I managed to install the drivers with the guide but now I´m stuck.
I don´t mean to complain, just asking if theres something I´m doing wrong or something I don´t get right here
I am SO SORRY! A few days ago our links got messed up and I had to remake them!
I made a BAD mistake. The file mk808_f_b_update.zip is the STOCK ROM for the FAKE MK808 B.
This is not the correct ROM download.....
This was the stock ROM in update.img form. I made this mistake YESTERDAY so if you downloaded it before you are OK.
Craxx, you are OK that is the correct ROM.
Again I am SORRY I messed up the link. It is now fixed in the first post. File name should be:
mk808b_finless15.zip
Guest
Okay thanks for the quick reply, I thought there must be something like that going on, because those files just didn´t seem to be right
Originally posted by Craxx View PostHy Bob,
now when you are here.... do you plan a new update for MK808b in the next time ;-) :-D
best regards
Craxx;-)
You willing to be crash test dummy since I cannot test it as I do not have a B?
Now we have a full 1080p kernel patched by the original one, vmirage in other forum did this work:
Actually I use this ROM with this kernel and works really good.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I have a CWM nandroid backup ready to reinstall if something fails
And if you want you can use the new patched kernel. If I can help only say me howREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by Finless View PostOK give me about 1 hour to make BETA test ROM. OK?
BobREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
AW: NEW - MK808-B mini TV Player - Finless 1.5 Custom ROM
Hy bob
I am also a crash test dummy ;-)
My cwm is also working and i have several backups.
The new patched 1080 kernel i tested. But for me the text and icons are too small and it lags little bit, so i prefer a 720 rom or the ability to change resolution in settings if that is possible.
Craxx;-)
Send from my Nexus 4 with Tapatalk :-)
Originally posted by leolas View PostSure
craxx, I am supplying a boot720.img and a boot1080.img So you can shoose boot.img for kernel you want. By default this ROM will be 720.
Craxx;-)
I tried a lot of times compile it, and it works well at 1080, but no luck with wifi and BT, RK903 is hard to get it working with our current sourcesAnd I am not skilled enought to make it work
Good work Bob i am making a new backup and waiting for itREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Last edited by Finless; 31 January 2013, 17:36."Pzebacz im, bo nie wiedzą, co czynią"
There are currently 2194 users online. 2 members and 2192 guests.
