Another clone! (CX803 - FX5) but with external antenna and reset switch button!!!
    Originally posted by zibel View Post
    Hi Bob
    Tested your rom everything is working flawlessly wifi and mic tested it with sound recorder and it record fine.Think there is nothing to test anymore only the cosmetic part of the rom.Thanks for everything.
    Sent from my LG-P990 using Tapatalk 2
    Sounds GREAT!
    First person to give me artwork for this ROM, I will cook the final ROM with your artwork!
    I also have a few things to add to the ROM that I did not want to add for a BETA. So a little more tweaking
    Did you all like the customized wood grain launcher from the stock ROM? I kind of liked it. I can put that back if you all like?
    Anything else?
      Sounds GREAT!
      Anything else?
      You're the man, Bob
      With many thanks.
        Hi Bob
        Hi, zibel
        Does the ethernet work too?
          Wifi is to weak.wifi works but it does not pick up my router.it was picking up with stock rom.otherwise brilliant work.video playback works just perfect.thanks for great work Finless!
            a little bit unrelated - but anyone here know how i can spoof the thing to believe it doesnt sit in UAE but in Switzerland? I do have VPN active but somehow the device recognizes it comes from uae and doesnt allow me to allow some apps i'd like (SwisscomTV). From where is the country info taken?
            EDIT: well - got around it by creating a 2nd account. stupid google functionality..
              Originally posted by ilearner View Post
              Hi, zibel
              Off course not ilearner
                Sounds GREAT!
                Anything else?
                Hi Bob
                Think you could replace the stock lancher with the grid launcher cos it kind of look ugly on a tv lol.1 bug i found but not yet confirm is that my measy rc11 airmouse is not working on the rom anyone else has airmouse problem?
                  Hi Bob
                  Disregard my airmouse problem cos battery is low no bug at all.
                    done some further testing. Looks like the stick tends to loose wireless connection after some hours. reboot helps to get it back (but shouldnt loose in first place)
                    playback of video has issues. default player works best - other players like bsplayers etc dont really work (start video but it's all artifacts)
                      I agree with you on the wireless there weird bug but on the stock rom it happen too.I got 1 problem with browsers any browser i install after like 10-30 min or so they won't load and seem to stuck and do nothing even on dolphin and stock.Do you have that bug too?
                        hey zibel where did u buy the stick in singapore? read my pm lol
                          have it in browser but also google play and other internet accessing apps. only have device for a day,so cant say if it's in stock as well. thought it could be that wireless goes to sleep and doesnt wake up. dont think it's overheating cause then it wouldnt work on the immediate reboot, neither.
                          wondering which app to use in order to access a network drive (Synology NAS) and watch videos of it.. so far havent really found something working. but could be beta-effect.
                            Yeah i bought it at GMarket
                              wireless weird bug
                              i wanted to choose this over mk808b, but seeing this wireless bug, should i still buy cx-803?
                                Re: Another clone! but with external antenna and reset switch button!!!
                                Cant say which one is better cos i dun have a mk808 so i cant judge but this stick think going to be huge this year with many firmware upgrade
