NEW - iMito MX1/2 - Finless ROM 1.7
Originally posted by apache View PostFor my case, to successfully flash new ROM, it only works if I connect the device to the power outlet using an adapter, and the other USB cable to the computer.
Only I've just bought/ordered a second hand stick, with only the power cable..
Is it just a 'normal' mini usb (otg), or micro or something? (Can't really see from a photo; and some sites say mini, some micro..). I guess it's micro.. but If I order one, I want to make sureLast edited by cranfan; 02 April 2013, 17:25.
RKRemoteControl...
Hi!
Thanks for the ROM!
I had a weird issue though, the shutdown button in the taskbar seems to corrupt my device. I used it only 2 or 3 times and twice it has scrap the OS (UI system failed to start after reboot)... I had to re-flash the ROM.
Since the latest 1.7 (1080 version), the RKRemoteControl app on my cell can no longer find the IMITO Mx2 on my network. Does the server side app is missing from the new ROM? I had an early version of the 1.7 (at the time it was still identified as BETA) and it was working. I don't understand why it is not working anymore!
Anyone can help me or confirm that it works for them?
Other than that, the ROM is awsome! My MX2 is so much better than it was with the original ROM!
Cheers!
RK remote is there and works fine for me. I have tested it several times.
Key things
1) It wont work on Ethernet only wifi unless you do some tricks with it.
2) Both devices must be on the same network
Now I have never tested it on a 1080 kernel so maybe that is an issue?
As for corruption. Last guy I helped with this problem it was some APP he was installing that makes /system RW and has some file open. Shutdown thus corrupts. Please make sure it does this from a fresh flash. I bet you will find it does not. Also do not use it for SEVERAL minutes after first boot up. The system is setting up files in /data which can take about 4 full minutes. If you reboot before it finishes, it will corrupt /data.
RK Remote Control
Thanks for helping! by the way, I have tried to figure out thus corrupts apps but I dind't find anything so then I flashed again and didn't install any app before testing the RK Remote Control and it still doesn't working for me. How can I check if the server is installed and running? I really appreciate your effort and well done work with this rom and wonder if I could get this app running.
I'm not an expert in android but I'm familiar with.
Please, If you have any other idea, please let me know.
Regards.
Thanks for the reply.
For the power button, i believe you! But since everythings has been setup already. I would rather like to leave it like that and try not using the shutdown button! lol
For the RK Remote, that is strange. Both device are on the same network. I used it a lot before the last re-flash of 1.7 (from 1.7 too).
You wrote on the previous page that you will have a new patched version of 1.7 for the 1080 kernel! What is i going to fix?
Thanks again!
NEW- Measy U2C/B12 Finless ROM 1.7(720P) on Mk809II
With NEW- Measy U2C/B12 Finless ROM 1.7(720P) on my MK809II, without OC or any mods: untutu - 9400 points.
With 1.7a or 1.7b i was getting something around 7600-7800 points without oc, and with oc 8200 points.
How much is your score with 1.7a or 1.7b??
Originally posted by klikzord View PostWith NEW- Measy U2C/B12 Finless ROM 1.7(720P) on my MK809II, without OC or any mods: untutu - 9400 points.
Ok, I flashed the ROM.. (thank you for this), but sometimes I have to reboot (or does this on its own), XBMC freezes and some other apps.. lost of freezing.. :/ etc.. Or XBMC just stops.. when installing or booting..
Can't use it without freezing or rebooting..
(or even no signal).
Do you think it could be a power (adapter) issue? Or is it another problem?Last edited by cranfan; 06 April 2013, 10:58.
Originally posted by cranfan View PostOk, I flashed the ROM.. (thank you for this), but sometimes I have to reboot (or does this on its own), XBMC freezes and some other apps.. lost of freezing.. :/ etc.. Or XBMC just stops.. when installing or booting..
Do you think it could be a power (adapter) issue? Or is it another problem?Please consider making a Donation to freakTab
how do I get the bar at the bottom back?
it disappears after xbmc and I have no idea how to get it back. What can I do? Currently I reboot
Edit: More info: 1.7a, 1080p, on mk809ii. Is there a launcher app to start?
Edit2: And yes, I know that "Settings" should get it back, but it does not. I have at least 3 different "Settings" apps. None gets the status/task bar backLast edited by ropo; 07 April 2013, 13:01.
Originally posted by blinkone View PostHi iv got the mk809ii with finless 1.5 imito rom (great rom by the way) & i had the freezing & shutting down problem,i brought a good 5v 2 amp power adapter & the problem has not shown up since so i would give that a go
Lots of money down the drain..
(New flash.. again.. don't know what else to do). How is it possible this works on other Imito MX1 sticks?
Didn't work either.. keeps freezing.
Trying 1.5 (720).. freezing.
Can anyone please help.. really can't buy yet another stick..
If I boot 1.5, the first couple of seconds I seethe 1.7 loader, then 1.5 boots...
typing this now on tv..
but I erased nand, so why does this happen....??
Ok, erase Nand again, flash 1.7 again.. seems to run ok.. but then.. freezes..
I used windows 8, is that a problem? (driver installed).
And I had to use the alternate/switch method..
1080 same problem.
Even flashed with the reset button/to connect to pc..
don't know what I'm doing wrong../what is wrong.
Still the adapter.. don't think it is the problem though..
I will try the Imito firmware.. to see if it makes a difference (I would rather use Finless but ok). Doesn't see the update.img on the sd.. just boots 1.7.. maybe with bootloader..
No one with an idea why this is happening? The freezing..?Last edited by cranfan; 07 April 2013, 18:57.
Originally posted by ropo View Postit disappears after xbmc and I have no idea how to get it back. What can I do? Currently I reboot
Edit2: And yes, I know that "Settings" should get it back, but it does not. I have at least 3 different "Settings" apps. None gets the status/task bar backPlease consider making a Donation to freakTab
There are currently 2521 users online. 0 members and 2521 guests.
