NEW - iMito MX1/2 - Finless ROM 1.7
Re: NEW - iMito MX1/2 - Finless ROM 1.7 (beta is over)
hi, i'm using 1.7a on mk802iiis..
i'm able to make tp-link tl-wn823n (realtek 8192) usb wifi adapter to work using rtl8192cu.ko module (from armtvtech, forgot the link).
so i replaced rkwifi.ko with that rtl8192cu.ko (renamed original rkwifi.ko --> rkwifi.ko.old, and rtl8192cu.ko --> rkwifi.ko).
but upon reboot, my stick still use its internal wifi instead of external. i had to manually insmod the new rkwifi.ko to make it work again.
any suggestions?
thanks
Sent from my GT-I9100 using Tapatalk 2
If you look at ROM normal boot rkwifi.ko is not insmodded. Wlan.ko is. Reason is wifi drivers are in the kernel.
So to use another wifi device it has to me insmodded. Also you do not need to rename it rkwifi.ko.
So if you are using my ROM you have init.d support. You can make a simple script and put it into system/etc/init.d.
First copy in the rtl8192cu.ko module into /system/lib/modules/
Set permissions to match other KO files in there!
Make a script called 00rk8192.sh
In the script put this:
#!/system/bin/sh
insmod system/lib/modules/rtl8192cu.ko
Make sure to leave one blank line at the end of the script or it will not work!
Save this file and put it in /system/etc/init.d
Set permissions on the script to RW and Execute.
Now when you reboot the rtl8192cu.ko should be there. To check open a terminal emulator and type
su
lsmod
you should see it listed.
Originally posted by netghoster View PostCould you please share the brand and model of your Ethernet USB adapter? Thank you.
ASIX Electronics Corp. AX88178 (0b95:1780)
It's a gigabit adapter
Trendnet TU2-ETG (Version v2.0R)
Regards,
Enviado desde mi GT-P5110 usando Tapatalk 2
Hello again,
One question:
I have a remote control Measy RC13. This rc has audio hardware, (mic+speaker+stereo jack for audio out). Every time my machine boots, it choose this audio device by default and I have to go to audio/sound settings for change to "HDMI" device.
How can I automate this?
Regards,
Driver USB-LAN adapter HG20F9
Dear Bob,
First I want to thank you for your effort regarding the ROM for the MX1. I am really enjoying it!
Because I am stuck with inserting a driver for the USB to LAN adapter (http://dx.com/p/usb-2-0-to-rj45-100-...r-black-160154 ) with a 88772 chip (see also: http://www.slatedroid.com/topic/4714...18#entry535018 ) and you are very familiar with programming, I would like to ask you if you can give me some directions or include this driver in the ROM to make this device work in the MX1/2 Android player.
Thank you very much in advance for taking the time.
Kind Regards
Marcel
Regards,
Is your ethernet adapter getting a lower download speed than your wifi using speed test app? I have Cat 5e and Bobjgear ethernet adapter and I am getting lower speed on ethernet than the wifi?? what is your reading? I have a 50 gb service and I am consistently 20 mbs with ethernet adapter and 30s with wifi. My windows OS Vista is getting 50s mbs from the same router.
my adapter : http://www.amazon.com/BobjGear-Ether...ref=pd_cp_pc_2
Thanks in advance.
Regards,
Thank you. I will probably order the same.
Thanks in advance.
This sounds logical, your adapter it's a fast ethernet adapter, 10/100Mbps.
My adapter it's a gigabit adapter, 1000/100/10 Mbps, but limited by theorical usb 2.0 speed at 480 Mbit/s (60 MB/s).
Internal Wifi N it's at 300Mbps.
This speeds are theorical. But, if units don't lie me, the limited gigabit wins vs wifi N.
I don't know if is your case but, also internal wifi on my MK802iiis is very unstable with every rom that I has probed.
With this gigabit adapter, from what I've tasted, exchanging data with my computer with windows 7 reached speeds of 15Mb/s. Not much, but more and especially more constant than wifi.
If you want, tell me a test speed and I give you my measure, but my adsl it's limited to 3Mbs. Yes, it's very slow.
regards,
I am a new MX1 user, just got it yesterday from Amazon, Geekbuying seller. So far so happy. It came with the 1.5 ROM, so I won't to flash it to 1.7a, because of the 1080p support. The problem is the link for the rockchip driver in Dropbox is missing. Where else can I download that file ?
THANKS !!
OPS: I am sorry just downloaded the 250meg file and noticed everything is inside !!! SORRY FOR THE POST
Originally posted by untyped View PostI am a new MX1 user, just got it yesterday from Amazon, Geekbuying seller. So far so happy. It came with the 1.5 ROM, so I won't to flash it to 1.7a, because of the 1080p support. The problem is the link for the rockchip driver in Dropbox is missing. Where else can I download that file ?
THANKS !!
If you do movies on xbmc flash 1.7a...otherwise lots of problems with xbmc playback.
regards,
Originally posted by untyped View PostSo it is better not to flash to 1.7a ?
No, I would suggest, if you are going to use xbmc, that you do flash the Finless 1.7a because it adds hardware accelerated videodecoding files that improve xbmc's use of mx player, etc. immensely. Use the xbmcandroid.com settop box version of xbmc with external player. Works great for me.
There are currently 2614 users online. 1 members and 2613 guests.
