Are there any fw versions for MX1 supporting external 3G dongle? Thanks
NEW - iMito MX1/2 - Finless ROM 1.7
The manual hide bar is there. Just not when your on the desktop home screen. When you launch an APP it shows up on the system bar again. Yes XBMC needs to allow you to hide it within the APP like other APPs do. I do understand when you run XBMC and then manually hide the status bar the mouse is off. I am not sure what to do about that.
Originally posted by Finless View PostI do understand when you run XBMC and then manually hide the status bar the mouse is off. I am not sure what to do about that.
UPDATE: I installed the XBMCANDROID.COM version of XBMC and with auto hide enabled, the menu is still visible, however, when you actually play a video, the built in player sees the auto hide and shows the video full screen while the official XBMC version does not hide it when playing a video. If you have not tried this version, you should as it already has ALL the major plugins installed by default with direct icons to them from the main screen, such as 1Channel, Icefilms, and Project Free TV. Very stable and works great with MX1 and Finless 1.7
BETA is over
Based on feedback I am calling this beta test over. The ROM links are the same and are considered the launched ROM from me.
Enjoy,
Congrats, Bob. 1.7a looks good to me.
The major "tweak" for me was changing to 240 density (with the 1080p display) which seems to be working well with my software and the Go HD launcher. With 160 density I could not get the desktop icons and text or some software screen text to readable size with the available settings. Also using the "large" font setting caused overlap problems. So, the 240 density change was completely necessary. After that "normal" font and icon sizes worked just fine and I've seen no glitches. It would be easier for Android newbies like me if there were a setting for density and perhaps the hardware ID you customized, or some way to more simply swap between build files, but I guess that would be a lot of work for something you guys think of as trivial. However, simplifying key element options like that would make your ROMs mainstream.
Also, what's involved in making ROM img files? It sure would simplify installation if you had 720p and 1080p img files.
Regardless, thank you for making my MX2 work so well.
Bill
Originally posted by jjwalker2 View PostBob,
I haven't come across any issues with 1.7 yet but have a question regarding the coding and the iMito display output. The Comcast Xfinity TV app will not play any video because it thinks that the HDMI output of the iMito is a secondary display. Is there somewhere in the ROM that reports this that can be changed to consider the HDMI output as the primary display?
Thanks, JJ
Build.prop question
Bob:
In the section of the build.prop file where you made your performance tweaks, you change the wifi supplicant scan interval to 100 and comment out the 15 setting line. However, later in the file under Additional Build properties I see the wifi supplicant interval 15 line again not commented out. Won't this defeat the 100 setting? Sorry I didn't notice and ask about this earlier.
Bill
Bill
Samba Filesharing
Hello,
I installed the version 1.7a 720p on my MK802iiis.
I can not run Samba Filesharing. The app starts but when I try to enable it closes.
Anybody knows any app to share drives with my pc?
Thanks in advance.
regards,
I edit: After a hard reset samba is working.Last edited by jpci; 06 March 2013, 20:17.
THANK YOU
I just registered to thank Bob for this 1.7 ROM.
I just loaded it this afternoon and am up and running smooth.
I greatly appreciate the effort and work that has gone into making this.
Great icing on the cake. I was really hesitant about buying an Imito MX1 and had been running the finless 1.5 since I got it in early January.
Now my TV seem to be much sharper with better color saturation.
I still get a little stutter or hesitation with questionable video files, but the improvement on NETFLIX is amazing.
Thanks man!
There are currently 2145 users online. 2 members and 2143 guests.
