NEW - iMito MX1/2 - Finless ROM 1.7
Did you update voice search fromt he play store? You have to do that as the built in one has bugs and the new one cannot be a system APP so I could not include the updated one in the ROM.
My ethernet dongle works fine. What do you have?
Almost all JB ROMs have these drivers in lib/modules regardless if they are also compiled into the kernel. These are the standard provided drivers from RK SDK.
If you try and insmod them and get an error it means they are already in the kernel.
Originally posted by MikeyTG View PostThanks Bob for the great ROM! Things seem to be working fine for me. One thing I did notice - when I try to "reboot into recovery" with the reboot app I get a picture of a dead android with an exclamation point popping out of his chest. I get the same thing if I reboot to recovery with ROM Toolbox so I don't think ii is the app. It comes back up to normal if I then reboot with the power plug.
Is recovery something supplied as part of a ROM or should I look elsewhere to get it straightened out? I am guessing that I don't have a recovery installed, but I am new to the android environment and don't yet have grasp on how all of the components map together.
I used the zip on the SD card method, it worked fine.
Originally posted by MikeyTG View PostI was able to fix my defective recovery by installing clockworkmod from here:
But glad you got CWM and can do what you want. Just realize this. You will never be able to use the stock update.img from SDcard now. Thats the big difference.
Originally posted by Finless View PostDid you update voice search fromt he play store? You have to do that as the built in one has bugs and the new one cannot be a system APP so I could not include the updated one in the ROM.
The ethernet dongle.....have to get back 2ya on that one....**** bubble wrap special brand. Mini usb to ethernet , i bought it for my mk808. Just using a mini to micro patch cable for the MX1 OTG port....It worked O.K. with all other Rom's.
Anyhoo....The issue of my MX1 only being stable with Alexs' kernel Shytes me to tears. I'm sure you've heard it all before so I'll sing to my cat.
Originally posted by felix80 View Post
See this:
This is a rockchip thing.
There is a Rockchip tool to program the eeprom in the chipset to fix this:
http://minixforums.com/threads/mac-address-issues.80/
BUT... now that I know this, I think I can solve it in the ROM. But before I do please someone with this issue try the tool.
Originally posted by Finless View PostAHA! This is the clue! For your hardware they have not programmed a MAC or BT address! You for sure do not have a original or new ones are coming unprogrammed. So somehow clones or non-programmed chips are coming out now.
See this:
I've try this tool but don't work... the tool works fine, but when I connect my MK802IIIs again...
No IP address
No MAC address
No Bluetooth Address
All works fine with 1.5 version...
No IP address
No MAC address
What is this device exactly?
Also take the kernel.img from my 1.5 ROM and see if it resolves the issue. In this new ROM I am using the latest kernel so maybe somehting there.
Originally posted by mishtag View PostThanks Bob for answering my question.
And bakerbarber, which Rom you are using 1.7a or b, since I plan to use the ethernet adapter, so is it possible that one rom is working while the other one doesn't? Did you try both of them?
1.7a
I didn't try both. Bob recommended A and I have the MX1 so I ran with it. I did use the tool that loads the ROM to wipe it first. I rebooted a few times before trying ethernet. Worked first time and every time. However, some apps won't run on ethernet due to "run on wifi only" options and such.
Sometimes I switch back and forth from wifi to ethernet depending on what I'm doing.
There are currently 2497 users online. 0 members and 2497 guests.
