NEW - iMito MX1/2 - Finless ROM 1.7
Originally posted by dutchmaster18 View PostBut I will keep looking and trying. If I get any sucess I will be sure to share with everyone
Some things work for some, some things don't for others! I have seen here since we opened this place, that in fact people are searching for the best setup and I have YET to actually see people agree what that is!
So again, we all are learning with these devices..... MUCH more to learn I think
THANK YOU
Originally posted by dfgas View Postwhich is the better rom? 1.7a or 1.7b?
I get full signal on my 55" but its about a foot away from the router, however my other mx2 on my 42" is not so lucky but i am going through the floor and and at the side our my house. my router is in the middle of the house.
right now i have not found the perfect setup with xbmc which I am disappointed about which i know is not finless fault.
You simply have to pick and choose your media player with it. No single player works with all media. Wondershare is among the best, but I have 5 or 6 others to choose from the context menu. A hassle, but there isn't a file that I can't stream and have pefect playback once I select the right player.
EDIT: The latest nightly build of the XAF version of XBMC seems to work well w/o the SMB wrapper
On the other hand, I began investigating PLEX. Apparently these guys were involved in XBMC. Neither are perfect, but PLEX is well worth a try. The main hassle I had was getting the PLEX server to work consistently. I had to do a manual port forward (no biggie), and I had to disable my software firewall. Neither Windows Firewall or Zonealarm would accomodate the server despite all my attempts to get them tuned to it. Plex has icefilms and Navi plug-ins. I can't get its Netflix plugin to work, but the Android app works fine for that. Other than that, PLEX is pretty darn good.
Bob, sorry for the thread hijack. Oh, and thanks for your expalantion of why you don't do your ROMs as single img files.
BillLast edited by billbmsn; 03-12-2013, 18:48.
Originally posted by dutchmaster18 View PostSorry. I did ask this in the beginning of the thread. I want to map a network drive so I can play music from my computer as well as save my downloaded torrents and stuck on my drive on my computer
Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
There's a link posted above to YouTube with one of my videos with hopefully a taste of what Plex and the imito can do
Also on my YouTube account there are a couple of other videos regarding the Imito MX1 and at least one of them regards Plex too.
Hope this helps in some way
Re: NEW - iMito MX1/2 - Finless ROM 1.7 (beta is over)
Originally posted by Finless View PostAn SD update can be made but understand
1) The SD update method will not flash a new kernel
2) It will not change the parition space!
The other way is to maybe ask Leolas to make a update that uses CWM.
I think this is easy to made for everybody. Only need to choose the. img files you want and put them inside the zip. But I want you download the roms and the recovery from their original links, if not, people think that I made the roms, no matter how big I wrote that is not my work.
But I can make zips for the roms you made and give the Rom creator the links so they can publish them in their threads.
Now I am very stucked with kernel work, cause I cant make internal WiFi works, I think I am killing flies with heavy guns with kernel work :PREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Flash back to Imito MX1 Stock Rom
How do I flash back to the stock Firmware afer finless 1.7A has been installed ?
I am have a few issues with my MX1 after the finless rom install
- Wifi name displayed is all 00:00:00:00......
- Date and time wont stay after I fix it?
Thanks for your time
- GaryLast edited by gnalen; 03-12-2013, 22:03.
time changes after power off then back on.
Flashed 1.7a on mx2 here its a lot better compare to stock, many my apps runs properly now.
only one problem its every time i power off restart the time is off.
First i unchecked Automatic date and time use set time and date changed Time zone form GMT-00:00 (default value) to my time zone GMT-04:00 Eastern but after reboot give me the wrong time then i check back the Automatic date and time but still after reboot time is off..
i don't even care its wrong time.but if time is wrong my wifi will not connect correctly.
any ideas? Thanks in advance.
There is no battery in these so they do not hold time on a reboot. It must get time from the network. If your getting the wrong time then either your routers time is wrong or your ISP NTP time server is wrong.
If you give me a logcat dump I can look and sere where it is getting time from and why it is off.
Rom Help
Hello bob, I am have some of the same Issues. I just checked my router an it has the correct time, it must be getting it from my ISP.
- My Time and date wont stay, even if I manually enter it
- My Wifi Name is 00:00:00....
- Keeps rebooting ?
Can you tell me how to flash back to stock IMITO so I can check this ? or do you have any other Ideas so I can keep using your Rom?
- Gary
I need a logcat dump to see where it is getting time from.
get terminal emulator from Google Play and install it.
reboot
After reboot run terminal emulator and type
su
logcat
You will get a logcat dump. Copy this to a file and post it here.
Never mind. The info needed is not in logcat! DAMN.....
I have to research how this is set and used.
For me this only started to happen when I flashed it with the 1.7a Rom, I was using the stock Imito from november.
Is there a process for going back to the stock firmware, so I can test it?
- Gary
Originally posted by Finless View PostNever mind. The info needed is not in logcat! DAMN.....
1.7a?
That's for the mk808 not the initial!
Just download the stock rom from geek buying and flash it!
There are currently 3031 users online. 5 members and 3026 guests.
