NEW - iMito MX1/2 - Finless ROM 1.7
Originally posted by netghoster View PostThank you for the reply.
I like the auto hide feature. Just once in a while, I have the need to bring it back on. Not a big deal. I can always to switch back to home screen to bring it back.
It was posted in this forum, thanks to whoever posted it!
Originally posted by Fox0 View PostTried to flash my Imito today everything worked fun, but when i wanna boot my Imito now i just get the Boot Screen and after that it goes directly to a green Android with a Red Triangle is there a way to fix that?
I was able to recover from that situation by unplugging the power for like > 5mins. Not sure if it was the amount of time I waited or if it was my nth reboot that brought it back to the normal boot cycle. I know I tried to reboot a whole lot and it didn't work until I had given up
I had started to look at shorting the pins to put it in download mode, and reflash, but fortunately it never came to that. Hope you are as lucky!
Originally posted by rapalax View PostSounds like its trying to boot to recovery. I got that after accidentally selecting reboot to recovery from that reboot app included in the ROM. Now that I have CWM installed, this is never an issue for me.
Anyone a idea what the problem is?
A question to Bob about tivizen and iMito 1.7
Hi Bob, first of all thank you very much for your work. I've got a MK802iiis and I've tested all the rom for this device and the ones you did for the iMito works pefectly and better than all the custom rom designed for that device.
I've tested your version 1.7a and it works much better than the b version on MK802iiis the only problem I've got is to let the rom works with the tivizen iplug device so i've back on iMito 1.5 (1080p version) where it works perfect.
So my question is there is a difference between the two rom in the way they interact with wifi? Because tivizen iplug create a local wifi network but with 1.7 i can find the device but i't won't connect.
Thanks in advance BobLast edited by us1929; 16 April 2013, 13:16.
Originally posted by mercdoc View PostI have tried several times to get my MX1 to reboot into flash mode without success with either .exe. I am booting from usb power to OTG port. I ensured debugging is off and usb is mass storage. And it fails everytime to get to flash mode. It says that it is rebooting, I get the black screen but tool says no device connected. When i use the ALT tool, I see the pink. click switch and it fails. I have been able to update by side loading with microsd. What else am I missing? Thanks in advance.
This is how I flashed my stick yestarday after many attempts to start the stick in flash mode as descripted on the bobs README.
Originally posted by us1929 View PostHi Bob, first of all thank you very much for your work. I've got a MK802iiis and I've tested all the rom for this device and the ones you did for the iMito works pefectly and better than all the custom rom designed for that device.
hi guys, I have problem with Remote Control using RK Remote APP in finless 1.7
I have install the app on my android phone,click the search device button and can't find my mk808b
there are connect in the same wifi but
Editops This is a mx Topic, sorry
Originally posted by Monochrome View PostIs there any way to hide permanently on screen keyboard? It pops up every time I write. I am using Logitech bluetooth keyboard.
i flashed the rom on my ug007II.
the rom works great.
but cwm is not workinig.
when i use the reboot app too recovery .
then the stick reboot but i get the droid with the ! mark.
with recovery must i use on this stick.if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Stock recovery does that because it finds no update.img on sdcard.
You need to install CWM if that is what your looking for.
Originally posted by Finless View PostStock recovery does that because it finds no update.img on sdcard.
Bobif you love my work please buy a coffee
</form>
There are currently 2864 users online. 0 members and 2864 guests.
