I had an error from incomplete download - I got stuck on the boot screen. Annoying to have to remove case (and break it), put device in recovery using pins and then reflash.
NEW - UG802 Finless 1.8 Custom ROM
Originally posted by gontera View PostI have the same issue. Now I am trying to flash v1.7 ROM back.
Ps: Bob thanks again for your splendid work!
Re: NEW - UG802 Finless 1.8 Custom ROM - BETA
Originally posted by greg121 View Postsame question here
Originally posted by laffo_2 View PostHi Bob,
Have a question, pretty new to this. I have a ug007, I take it that this rom is compatible?
Also, I am looking for touchscreen support for the ug007 for use with Joy2touch.
Are there any roms where this is possible?
Thankyou
JIM
ICOO D70PRO II
Hi Bob,I bought UG802 2 days ago and my only issue was that I wasn´t able to get any apk from Google play store.I didn´t have any issue with wifi and could without problems watch youtube etc.
After flashing to Finless 1.8 BETA ROM I have no more issue with play store(thanks a lot!), but I have a new issue with speed of wifi connection.My wifi connection is now at least 10x slower than before flashing to Finless 1.8
Any idea how to fix it ?
Originally posted by rapalax View PostIs it possible to flash this from CWM or use the update.zip method ? I am running windows 8 and the flash tool seems to have issues recognizing the rk3066 USB device. It was a bit of a pain using my wife's win7 PC to do the job :/
Originally posted by nemesiscbm View Posthi Bob, Thanks for all.
I used Finless 1.7 in my MK802 III and work fine, I used 1080P kernel OC , can put this kernel in this rom?, I want used 1080P kernel , I only used de android TV for player MKV 1080P.
sorry for my english i from spain.
There are currently 1882 users online. 1 members and 1881 guests.
